What is the Total Impulse Applied to the Box?
  • Thread starter Thread starter yesiammanu
    Impulse
2 replies · 2K views
yesiammanu
Horizontanl force F is giving by F(x) = (2.00x + 1.00x^2) Newtons, acting on a 12.0kg box which is initially at rest and on a frictionless horizontal surface. Force is applied from x=0 to x=2.50 meters. What's the total impulse the force applies to the box?
v^2 = sqr(2ax)
Impulse = mv1 - mv0
F = ma
I already got the work, which was 11.5 J
2.00(2.50) + 1.00(2.50)^2 N = 11.25 N
Now I must find velocity
F = ma
a = f/m = 11.25 N/ 12kg = .9375 m/s^2
v = sqr(2 * .9375 m/s^2 * 2.50m) = 2.16 m/s
12kg * 2.16 m/s = 25.9 momentum
Since it started at rest, the momentum should be 25.9 . However the answer is 16.6 N * s which I can't understand how to get
Another attempt using joules would be , since Joules is kg * m^2/s^2
11.5 J/ 2.16 m per s = 5.32 momentum which also isn't right. Any help would be appreciated
This equation is not right because it is not constant acceleration. (it will only work when the acceleration is constant).
Your value for the work is correct. You can use this to find the answer. What is the equation for the kinetic energy?
