What is the Work Done by a Pitcher on a Baseball?
  • Thread starter Thread starter goalieguy
    Ball Work
The discussion revolves around calculating the work done by a pitcher when throwing a baseball. The initial calculation of 2.911 Joules was incorrect due to a failure to square the velocity in the kinetic energy formula. The correct formula is (1/2)mv^2, leading to a final answer of 119.351 Joules. Participants emphasized the importance of careful calculations and checking each step. The conversation highlights common mistakes in physics problems and the value of peer assistance in resolving them.
goalieguy
A baseball leaves a pitcher's hand at a speed of 41.0 m/s. The mass of the baseball is 0.142 kg . Ignore air resistance. How much work has the pitcher done on the ball in throwing it?
I've tried using (1/2)mv^2, but there has got to be something weird going on, or i could just be using the wrong equation
thanks for any and all help :smile:
work
i work it out and get the same thing every time i have tried it.
2.911 Joules is the answer I get, and WebAssign says that it is incorrect.
How are you getting that answer? Show what you did.
sorry
Sorry about not showing all the work.
I just take the givens: v=41.0 m/s m=0.142 kg
Then I plug it in to: \frac{m*v^2}{2}
\frac{41*0.142}{2}
That is the answer i come up with (2.911 Joules)
square your 41, boy!
duh. thanks i knew i was doing something completely dumb.
always got to forget the easy part.
right answer = 119.351 Joules
thanks a lot
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
