What is the Young's modulus of a nylon rope used for climbing?
The Young's modulus of a nylon rope used for climbing can be calculated using the formula E = (F * L) / (A * ΔL), where F is the force applied, L is the original length, A is the cross-sectional area, and ΔL is the elongation. For a nylon rope that is 41m long, with a diameter of 0.4 cm, supporting a 97kg climber, the calculated Young's modulus is approximately 82.46 x 108 Pa. This value is derived from the force exerted by the climber, which is 950.6 N (97 kg * 9.8 m/s2), and the rope's cross-sectional area of 0.0001256 m2.
  • Understanding of Young's modulus and its significance in material science
  • Basic knowledge of physics, specifically force and elongation
  • Ability to calculate cross-sectional area of a cylinder
  • Familiarity with units of pressure (Pascals)
  • Research the properties of nylon and its applications in climbing gear
  • Learn about the calculation of stress and strain in materials
  • Explore the significance of Young's modulus in engineering and material selection
  • Investigate safety standards for climbing equipment and their testing methods
Climbers, material scientists, physics students, and engineers interested in the mechanical properties of climbing gear and safety standards.
pietro18
For safety climbing, a mountaineer uses a nylon rope that is 41m long and 0,4 cm in diameter. When supporting a 97kg climber, the rope elongates 1,8m. Find its Young’s modulus. The acceleration of gravity is 9,8 m/s2
a) 82,46 x 108 Pa
b) 17,18 x 108 Pa
c) 25 x 106 Pa
d) 86 x 10 6 Pa
PLZ help
Pietro, please use one thread per HW problem. This cuts down on the confusion when folks want to reply to your posts.
Also, you must show an attempt at solution of your HW problem per the forum rules.
17K
72K
10K
14K
12K
