What is wrong with the following calculation using infinite series?
The discussion centers on the incorrect manipulation of infinite series leading to the erroneous conclusion that 0 equals 1. The main error occurs in the treatment of the series 1 - 1 + 1 - 1 + ..., which is identified as a divergent series that does not converge to a finite value. It is emphasized that for an infinite series to be well-defined, the partial sums must approach a limit, which this series fails to do. The conversation also touches on the conditions for convergence of alternating series, noting that the series in question does not meet these criteria. Overall, the key takeaway is that divergent series cannot be treated with standard arithmetic rules.
5hassay
0 = 0 + 0 + 0 + ...
0 = (1 - 1) + (1 - 1) + (1 - 1) + ...
0 = 1 - 1 + 1 - 1 + 1 - 1 + ...
0 = 1 + (-1 + 1) + (-1 + 1) + (-1 + 1) + ...
0 = 1 + 0 + 0 + 0 + ...
0 = 1
None.
Beginning on line 4, or
an error is made. Specifically, the repeating number 0 was not completely repeated. More specifically, the -1 number of the 1 - 1 pair to make zero was not inserted, thereby making this statement invalid.
Do I have the correct idea and am I missing anything? Also, any terminology I could have used is more than welcomed!
Much appreciation!
When you write a valid equation, both sides need to be well defined. When is the value of an infinite series well defined?
I think that the value of an infinite series is well defined when the partial sum Sn is close as it can to the limit L be adding infinitely many terms in the series (the sum).
So, if I took the limit of both sides of the equation (zero and zero), both sides will be equal to zero (the limit of a constant is the constant).
However, I do not believe I am providing the necessary statements.
0 = 0 + 0 + 0 + ...
0 = 1
None.
Much appreciation!
The reason this doesn't work is that (1 - 1) + (1 - 1) + (1 - 1) + ..., which is a type of series called an Alternating Series, does not converge (meaning it doesn't add up to a finite number) and diverging series do not conform to the normal rules of arithmetic. An alternating series is a series in the form
\sum_{n=0}^{\infty} (-1)^n a_n
The conditions for this series converging are:
\lim_{n\to \infty} a_n = 0
and
a_n < a_{n-1} \;\; \forall n
Since a_n = 1, this series would be
\sum_{n=0}^{\infty} (-1)^n = 1-1+1-1+\cdots
This series fails the first test.
\lim_{n\to \infty} 1 = 1 \neq 0
So it diverges.
This is actually a well known divergent series, known as http://en.wikipedia.org/wiki/Grandi%27s_series" .
Exactly, so now apply the same definition to the sum of 1's of alternating signs and as mentioned it does not converge so it is neither equal to zero nor equal to the series of zeros.
A bit of a nitpick, but this series is perfectly fine -- it is an infinite sum whose terms are all zero.
You're thinking of the next line:
1 - 1 + 1 - 1 + 1 - 1 + ...​
and
So it diverges.
We clearly don't need a_n < a_{n-1} \;\; \forall n, because what happens in the first N terms (for fixed, finite N) will not affect convergence.
RGV
Okay, I think I have a good idea of the problem and solution, however some of the replies were a bit over my current (basic) understanding of infinite series.
Thank you for everyone that replied!
