Adeimantus
- 112
- 1
Assuming ray optics model is valid, what lens profile focuses light to a point? It must not be spherical, otherwise there would not be the term 'spherical abberation'.
The discussion centers on the optimal lens shape for achieving perfect focus, emphasizing that spherical lenses are inherently flawed due to spherical aberration. The use of aspheric lenses is highlighted as a method to minimize aberrations, although a singlet lens can only achieve zero spherical aberration under specific illumination conditions. The conversation also touches on the mathematical implications of lens shapes, suggesting that hyperbolic lenses may provide better performance compared to traditional spherical designs. Various optical designs, such as the Ritchey-Chretien and Maksutov-Cassegrain, are mentioned as alternatives that address specific aberration issues.
PREREQUISITESOptical engineers, physicists, and anyone involved in lens design or optical system optimization will benefit from this discussion.
Andy Resnick said:The problem with your reasoning is that that ray optics model has a limited application. There is a "best form" to a biconvex lens, but the spherical aberration is not zero. Use of aspherics can reduce aberrations, but a singlet will only have zero spherical aberration for an extremely limited set of illumination conditions. For example, parabolic reflectors have zero aberration, but only for on-axis points.
In fact, simply reversing the orientation of a planoconvex lens will result in radically different amounts of spherical aberration.
I was wondering if it was a conic section. I tried to work this out when I was in high school but gave up after a while.lzkelley said:segment of an ellipse
Adeimantus said:Yes that's a good point. In practice the ray model is not good enough, and you can't realize the zero aberration ideal. I guess I'm asking more of a mathematical question then, but it is optics-related so I posted it here. I was thinking that the specific term 'spherical aberration' was included in the theory of ray optics, so that's why I reasoned that the ideal lens shape in the ray model must not be spherical. I am imagining a plano-convex lens with light coming from infinity, being focused to a point on the axis of the lens.
Andy Resnick said:The way aberrations are discussed in ray optics is very artifical, IMO. Ray tracing involves linear and higher-order approximations to the sine function- linear optics has no aberrations, but there are 5 aberrations in 3rd order optics (7 actually, but 2 of them- piston and tilt- do not affect the PSF) and more for 5th order optics with strange names you have not heard of, etc. etc.
So, you can see how aberrations form in optics- as the linear approximation to a sine function breaks down (say the numerical aperture of a lens increases), higher order terms are required for accuracy, and aberrations come along for the ride as a result.
Adeimantus said:That sounds like cool stuff you do. Thank you for the telescope links. I've only read a little so far, but I can tell I will find them interesting.
