What makes 0603 LEDs stick to probe?
  • Thread starter Thread starter rogerk8
    Leds Probe
The discussion revolves around the challenges of handling 0603 LEDs with pointy probes and tweezers, particularly their tendency to stick. Participants speculate on potential causes, dismissing dirt and considering magnetism, though the LED materials are non-magnetic. They discuss the phenomenon of components sticking due to proximity and electromagnetic forces at play. The conversation also touches on the possibility of ferrous materials, like nickel, being involved in the LED construction, which could explain the sticking issue. Ultimately, the need for non-magnetic tools is emphasized to avoid frustration when working with tiny electronic components.
rogerk8
Hi!
I had an interesting chat with a physisist colleague of mine this week.
Working with modern small electronic components I began to wonder why my extremely pointy probes, measureing the direction of the light emission diode, stuck so irritating hard to it that it could not break loose after I had established anode/cathode.
I also had trouble releasing it from the nippers with the purpose of soldering it to the tiny PCB pads.
So I asked my colleague why.
The too obvious reply was sticky dirt but neither him nor me really believed that.
Remember that these tiny LEDs weighs almost nothing.
We further speculated that there might be some magnetism in the probes like it is possible to magnetize something iron-like just by moving a magnet back and forth (which also is a strange phenomena because do you really have to move the magnet?).
I said that I don't believe that is the reason either and that is because the metal part of the LED is made of non-magnetic copper and tin so it doesn't matter if the probe or nippers is magnetic or not, I said.
Then he had an idea that perhaps things just stick to each other if they are really close to each other.
I did however refere to a scientific program I saw not so long ago that taught me that nothing really touches anything and this is due to the electromagnetic forces of the outermost electrons.
So what is the correct answer?
Roger
Bit of googling...
http://www.freetronics.com/pages/surface-mount-soldering-with-a-toaster-oven#.VDJmoGctDmQ
You'll need to place parts that are small enough to lose in the palm of your hand and if the tweezers are even slightly magnetised the parts will stick to them and you'll go slowly insane. I bought some super-fine non-magnetic tweezers from - you guessed it - Jaycar. Part number TH1754, about $5.
http://forums.adafruit.com/viewtopic.php?f=42&t=13258&start=15
Ha! My tweezers are too magnetic-- I find even 0402s almost impossible to use.
http://www.hobbyelectronics.net/tec_smd-soldering.html
A good quality metal pair of tweezers is also essential. They should be none magnetic as most SMD components seem to be ferrous and “jump” up onto the tweezers when you move in for the grab, making it very difficult to pick the components up properly.
I now agree that they seem ferrous but what is it whith that copper/tin/lead/gold alloy that is ferrous?
Is there perhaps some iron involed also or what is it?
And if it's iron or some other ferrous material, why?
To me tinned copper should suffice.
Roger
One candidate is nickel which is a very common "sticking layer" in electronics, a thin layer is deposited before the other metals to achieve better adhesion.
And nickel is of course ferromagnetic.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
