What materials heat up under pressure and for how long?
Certain materials, like rocks, can generate heat under high pressure, but the heat produced is primarily due to mechanical work rather than the pressure itself. While increasing pressure on gases can raise their temperature, this is not the case for solids or liquids under constant pressure without movement. The concept of work, defined as force times distance, indicates that without movement, no heat is generated. In geological contexts, significant heat is produced during seismic events when there is sliding between tectonic plates, particularly in subduction zones. Overall, constant pressure alone does not maintain an elevated heat state in materials.
tomta20012
what materials heat up under pressure and for how long??
I was just wondering are there any two rocks or combination of rocks that when their flat surfaces are pushed together cause heat? If the pressure is very high is that heat quite considerable??
or maybe there are liquids that do the job better? are there any two materials that heat up when under pressure??
and if under a constant pressure do they stay in a constant elevated heat state?
I'm sure a physics guy here would have the abilities to find that type of material even if it was lost
Science news on Phys.org
Temperature and pressure are independent from each other. High pressure does not cause heat. Said that, it's probably worth also mentioning the fact that increasing the pressure on a gas may cause its temperature to increase due to mechanical work - not heat - done on the gas.
Air works well for that.
But constant pressure will not do anything.
Energy equals Force times distance. (force applied to an object times the distance over which that object is being pushed.)
If the pressure is constant and nothing moves the distance is zero.
Work is force times distance. With seismic events, the Distance can be very small but the Forces are huge. The heat tends to be generated most when there's 'sliding' between plates. Look up Subduction. You get a lot of volcanoes in subduction zones.
Thread 'Can somebody explain this: Planck's Law in action'
Plotted is the Irradiance over Wavelength. Please check for logarithmic scaling. As you can see, there are 4 curves. Blue AM 0 as measured yellow Planck for 5777 K green Planck for, 5777 K after free space expansion red Planck for 1.000.000 K To me the idea of a gamma-Ray-source on earth, below the magnetic field, which protects life on earth from solar radiation, in an intensity, which is way way way outer hand, makes no sense to me. If they really get these high temperatures realized in...
  • · Replies 32 ·
