What programs are most successfull for visualization physical processess?
Neitrino
Gents,
what kind of physical processes?
REALTIME or static images?
static images-> maple/matlab/mathematica should all suffice
realtime->mmm depends, you can use a game engine to try some simulations
but you'lll be looking for code in fortran or c/c++. Oh wait VTK or PTC are open source so you can try to learn them.VTK might be your best choice, unless your willing to learn a game engine.
Processes of deformations of falling objects into the black hole or olaso may be deformations in solid physics. Just thinking to compare deformation visualizations in Solid Physics and deformations near stong gravity sources.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
