What proof do we have that TIME exists?
  • Thread starter Homesick345
  • Tags
    Proof Time
In summary, time is a man-made construct rooted in reality that is used to measure change. It is not a physical "thing" and is similar to other measurements such as inches or meters. The concept of time has led to extensive theoretical work in physics, with the nature of time still being actively studied. The alternative to time would be incomprehensible to us as finite beings. Consciousness does not affect the behavior of reality but is necessary for us to perceive it. The present is a constantly moving and evolving concept that is difficult to define.
  • #141
Drakkith said:
Define what you call "time" and "times", otherwise I cannot answer this.
sorry. i was thinking past present future.
Space news on Phys.org
  • #142
Here's my view. I can plot any dimension on a graph as a straight line. The position of a point on this line represents the position of an event or object within this particular dimension. Time is simply a line I draw and put points on. It is no different from a dimension in space in this context. I can plot things at any point along the line, including negative points to represent the past if I want. Just like measuring distance, I can measure time and define a unit to represent a certain "distance" on the axis that I want to use. Let's call it the second and define it as "the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium 133 atom."
So, now that I have my unit of measurement, I can set my graph up and plot things based on this unit and my measurement devices. (clocks) Similarly, the meter is the unit of measurement of distance and is defined a specific way and has a measurement device. So having a way to measure and plot both distance and time allows me to describe the universe.
If you have the urge to go "but what is time really?!", then I cannot help you. I could ask the same thing about distance.
  • #143
what i am getting at is : you could make a graph an hour. then wait one hour. upon examination it would seem to mark the passing of time. i could make the same the same graphs every two hours. when we compare these graphs they would appear the same. showing the same data. how would i prove they were different by the identical graphs? i can't even prove they existed a minute ago. all i have is some paper with data on it which exists only while i observe it.
  • #144
Chalnoth said:
Consciousness has zero effect on the behavior of reality (except the obvious bits like building houses, computers, etc.).
I'd disagree, many theories show that the presence of an observer is absolutely necessary for the construct of what we consider tangible reality. Schrodinger's Cat is a perfect example, that observation is required for the wave probability to collapse into a fixed state. I believe that the universe would exist without an observer, but at the same time, I think certain parts of "reality" are observer dependent, for example, the subject matter of this thread: time
  • #145
They wouldn't be very good graphs if we didn't label them properly would they? As to whether or not something existed prior to your current point in time, I don't think there is anything that can "prove" that it does without relying on certain assumptions, one of which is that objects exist at all points in time, not just when we are observing them. Otherwise my definition of time has no meaning.
  • #146
Would this not imply that time didn't exist without observers?
How did everything get into the state it was in which produced the first observer?
Did things simply appear in exactly the state to produce an observer, and at that point time began?
Perhaps the problem is due to our being unable to view time from the outside, and indeed having difficulty thinking in a fashion which doesn't assume the presence of time as a given.
We can do this mathematically though.
  • #147
That's completely and utterly wrong. Experiments have been done where they've collapsed wave functions without actually doing any observations.
  • #148
yeah that's the hard part and maybe i need to qualify what i said. our view of time, i think is observer dependent, but like you said, the role it plays, or rather played before observers, is exceedingly difficult to comprehend being that we can't step outside and reconsider its implications, thus making its limitations to our reality observer dependent
  • #149
Closed pending moderation
  • #150
This topic has ALWAYS produced a thread that eventually gets shut down. This thread has provided more evidence why the topic on "time exists or not" should be included as one of our banned topics.
Congratulations!
Zz.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
