What USB adaptor is suitable for a smartwatch?
  • Thread starter Thread starter Shervan360
    Charger
A suitable USB adapter for a smartwatch should output 5V, with the current rating being the maximum the adapter can supply, not what the watch will draw. Using a higher-rated charger (like 15W or 20W) won't damage the watch, as it will only draw the current it needs, typically up to 500mA as per USB specifications. Modern USB chargers are "intelligent" and communicate with devices to adjust current delivery based on their needs. Finding a compatible cable for the smartwatch may be challenging, but as long as the voltage is correct, the adapter will work safely. Overall, any standard USB charger that meets these criteria should be suitable for charging the smartwatch.
Shervan360
Hello,
I bought a smartwatch and it does not have a charger. The capacity battery is 230mAh. In the manual, they wrote input parameter should be 5V = 500mA.
If I choose a charger with high output power (15W (5V/3A), (5V/2.4A), 20W, or 65W), will the watch's battery be damaged?
Does the charger with fast charging technology and Power Delivery damage the smartwatch?
Please see the attached image. (The first image is from the smartwatch manual and the last three are Kingstar USB adaptors)
I don't know what USB charger/adaptor to buy.
Thanks in advance
As long as the adapter is puts out the normal 5 Volts DC (which USB chargers do), you will be fine -- the watch will draw whatever current it needs up to the limit of the adapter.
Look at it this way: take a look in the fuse box or breaker box where you live. You will find most of the fuses or breakers rated at 15 or 20 Amps. That is the maximum current they will allow before they break the circuit. If you have only a single 60 Watt light bulb turned on, the bulb will only draw the current it needs for 60 Watts.
The current rating on the adapters is the maximum current they CAN supply while keeping their output at 5 Volts -- just like the fuses or circuit breakers, the current rating of a Supply is the maximum available.
For Loads, like your watch or a light bulb, the current rating is the maximum it will ever Need to operate correctly.
The hard part may be finding a cable with a connector to fit the watch!Cheers,
Tom
I suppose you can be talking about USB chargers, not any chargers - and as far as I understand these have their own way of doing things.
They are "intelligent" - that is, they start by "talking" to the connected device, asking for the capabilities. If they can't get confirmation "hit me with the high current", they will somehow limit delivered current to just 500 mA, which is a standard USB specification. All higher currents are extensions to the standard, and won't be produced unless specifically allowed by the charged/powered device.
Likes Tom.G, berkeman and Shervan360
You are right, there. I just bought an Apple Watch which has a magnetic charger that holds the watch whilst charging and they say it needs a 40W charger. Then, I notice that most / all new laptops seems to use a USBC socket but specify high charger requirements. That stuff is very clever.
In the distant past, I remember suspecting that hp equipment would communicate with each other because they all seemed to agree with each other to within one sig fig. (This was pre-bluetooth etc)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
