What will happen if I use a air core for 50Hz current tranformer
  • Context: Undergrad
  • Thread starter Thread starter chudiandeyu
    Air Core Current
The discussion revolves around the feasibility and implications of using an air core for a current transformer designed to operate at 50Hz. Participants explore the differences between air core and iron core transformers, particularly in terms of inductance, output current, and linearity behavior.
  • One participant suggests that using an air core could improve linearity but questions its practicality at 50Hz, noting that air cores are typically used for high-frequency applications.
  • Another participant explains that lowering the frequency requires increasing the inductance to maintain the same maximum reactive input current, indicating that without iron, the inductance would drop significantly, necessitating a large increase in the number of turns in the primary winding.
  • A participant seeks clarification on whether the increase in turns refers to the primary winding and asks if the secondary turns can be decreased.
  • Further inquiries are made about how the output current would change with an air core and how to calculate the expected output current, emphasizing the relationship between inductance and output current.
  • One participant describes their specific setup involving a single-turn primary and a 500-turn secondary, asking how to calculate the secondary current with an air core and questioning the practicality of this approach.
  • Another participant shares a simulation of a Rogowski coil, providing insights into the expected output voltage and accuracy requirements, while discussing the limitations of using an air core in this context.
  • Participants discuss commercially available current transformer options that may meet the original requirements, suggesting that purchasing may be more practical than building a custom solution.
  • One participant ultimately decides to use a Hall effect sensor for their current probe instead of pursuing the air core transformer option.
Participants express differing views on the practicality and effectiveness of using an air core for a 50Hz current transformer. There is no consensus on whether this approach is advisable, and multiple perspectives on the implications of inductance and output current remain unresolved.
Participants mention various assumptions regarding the design and operation of current transformers, including the effects of core material on inductance and output current, but these assumptions are not fully explored or quantified.
chudiandeyu
I am thinking to use the air core to make transformer to get better linearity behaviour, but I found air core often use in high frequency,so can I use air core for 50Hz? what is the difference between high frequency and low frequency?
Thank you!
The equation relating voltage and current for a transformer primary is
V = L dI/dt, or
V∫dt = L∫dI
If you increase the period ∫dt by lowering the frequency, you will need to increase the inductance L in order to maintain the same maximum reactive input current Imax = ∫dI.
If you do not add iron, you will need to add turns to the primary. For example, if you remove iron from a 50Hz transformer, the inductance will drop by a factor of ~4000. You will therefore need to increase the number of turns by a factor of ~√4000 = 63 to compensate.
Bob S
@Bob S
Thank you for your answer
my transformer is a part of a current probe, so do you think it is reality to use air core for it?
and the 63 is 63 times the turns of the previous winding? can I decrease the secondary turns?
Thank you :)
@Bob S
What is the formula for the inductance and factor?
This is some more discrabetion of my question
I have a current transformer, it is soft iron core.
I want to change the core to air core to improve the linearity, but according to the information I checked, the output current will become very small.
I don't understand how will the output current change, it become small only because the inductance become small? And how can i calculate how small the output current will be?
The primary winding is a straight wire, and this current transformer is a part of a current probe. working in 50Hz.
Are you talking about a current probe that is measuring a steady ac current in a single-turn transformer primary (current probe) wire? For example a N-turn secondary on a transformer toroid that has a single-turn primary carrying I(ω) = I0sin(ωt) ? Please describe the situation in more detail. I have ordered special gapped toroids (to limit permeability) to measure 100 amp, 500 Hz signals on single-turn primary conductors. Is this what you want?
Bob S
My situation is a current probe for measuring ac current in single turn primary winding, and the current probe is a current transformer with secondary winding 500 turns, the current in primary wire is 10A and 50Hz.
So how can i calculate the current in secondary winding if i use a air core, and is it practical to use the air core?
Thanks !
This is an interesting problem. I simulated a 1-turn-primary, 500-turn-secondary Rogowski coil wound on a toroid with permeability = 1. The toroid is the only shape that will give a high mutual coupling inductance. The dimensions of the toroid were outer radius 4 cm, inner radius 2 cm, length 4 cm. This gives a primary inductance of ~5 nanohenrys. See model in thumbnail. The simulation shows that for 10 amps rms 50 Hz input, the peak open circuit output voltage is ~ 7 volts. This is limited by the shunt input inductance. To get 0.1% accuracy, you need to keep the output voltage to less than 7 mV and the output load to less than 0.2 ohms. So the maxumum output voltage is ~ 4 mV rms at 10 amps rms input. Normally, Rogowski coil output signals go into a transimpedance amplifier. To increase the maximum recommended output load (and voltage), the shunt input inductance should be increased either by using a longer toroid, or a coil form with a limied amount of permeability. How do you plan to process the toroid output signal? I hope this helps.
Bob S
There are current transformer toroids available that nearly exactly match your requirements. See the model TR-5025 in
http://www.toroid.com/standard_transformers/current_sensing_transformers/current_sensing.htm
It has a single turn primary, 500 turn secondary, 90 amp peak primary. The cost is probably ~$20.00 in unit qty (see bottom of page). It is not worth the effort to make your own at this price. I am not advertising this brand, but just letting you know that inexpensive ac current transformers with 1:500 turns ratio are available.
Bob S
@Bob S
Thank you for your answer i decided to use a Hall effect sensor to make the current probe:)
  • · Replies 43 ·
  • · Replies 60 ·
  • · Replies 17 ·
  • · Replies 25 ·
