Possible Causes for Hole in Radiator Tank
A hole in the top aluminum tank of an earthmoving machine may be caused by erosion corrosion, likely due to high-velocity water from the breather pipe impacting the tank wall. The surrounding area shows signs of bubbling, resembling pitting corrosion, but the rest of the tank remains clean, suggesting localized damage. The tan deposit observed is likely residue from a temporary repair and not the cause of the hole. Potential contributing factors include inadequate antifreeze, sediment in the coolant, or possible acidic conditions from combustion gases. Recommendations include redesigning the tank with a deflector plate and ensuring proper coolant maintenance to prevent further damage.
Joe591
What would cause a hole to form in the top aluminium tank of a radiator of an earthmoving machine. The tank material is 6mm thick and is made from 1050 aluminium plate. The material around the hole has bubbles almost like pitting corrosion or like somebody went and took a flame to it. The rest of the tank is clean and smooth on the inside, no signs of corrosion at all. I know it's basically impossible to say for certain, but what could be possible causes?
The piece of plate was cut out of the tank and the attached picture shows the inside of the area where the hole formed. The black piece that is stuck to it is a type of glue that the guys used to do a field repair
of the tank until they could get it repaired properly.
The second picture shows the general condition of the tank on the inside.
That top picture looks like it is taken from the inside tank side of the hole.
What is the tan material - is it part of the tank, or just a deposit?
The hole looks like it is corrugate aluminum - is that so?
Off hand, I would say it is chemical corrosion - perhaps assisted by some sort of biology.
It may have started at a small puncture point that allowed air and moisture in.
Yes, that's the inside of the hole area after it was cut out. The "tan"material is a deposit on the inside of the tank. It only seems to be on that spot. It might be residue of the glue that they used to patch the hole up. I'm not sure to be honest. You can see a bit of it on top of the tank on the second picture as well. If it was a steel tank I'd say it was rust, but it's aluminium. Maybe rust from the engine that comes and sits in the radiator top tank?
That deposit is not the cause of the hole - although it may be a contributor.
It also does not look like any aluminum salt - which would be white, and probably chalky.
So it's just a deposit, most likely created from the antifreeze or other coolant additives.
The dents in the deposit may have bee created in the attempt to patch the hole.
What does this hole look like from the front?
What does that mean? There is something heavy sitting on top of the tank? Is that at a contact point that could get worn by vibration?
Seems like some galvanic corrosion for me...
Likes Tom.G
Anything resting on the top of the tank like an unused filler cap or ?? I've seen vibration wear holes in things quite quickly.
A rust-colored foam sometimes found floating in the upper expansion tank, especially if there is a leak of combustion gasses into the cooling system. I also agree with @Rive that it looks like galvanic corrosion, which could also be from an inclusion in the original Aluminium. I suggest that compression and leak-down tests be done on the engine, just in case.
Cheers,
Tom
Likes CWatters
Where cracks form, corrosion is greatly accelerated by vibration.
Update:
We welded a new piece of plate into the tank and I wanted to inspect the repair area from inside the tank. To this end I wanted to shove our little endoscope into the tank. A quick look at the best fitting to use to this end led me to the breather pipe that is directly opposite where the hole formed. It seems so obvious now. We now think that water is coming through the breather at high velocity and hitting the opposite wall of the tank. I now think this is erosion corrosion.
Evidence for this is that the "corrosion" only seems to be in the area opposite this breather pipe. The rest of the tank is "clean", with no evidence of the pits at all. Recommended courses of action this side are to redesign the tank with a deflector plate that will prevent high velocity water from hitting this wall and deflect it downward into the water instead. We believe that during use some people are either not installing the 4mm orifice that is meant to prevent this from happening or they run the radiator too low on water and the jet hits the tank before it hits the surface of the water in the radiator. Either way it's causing crap. That's my best guess so far anyhow.
Likes Tom.G, berkeman and Nik_2213
Bit surprised that water alone is doing this. Is there something circulating in the water like rust or sand? Could it be acidic as a result of combustion products getting into it? Perhaps check it's got the right anti freeze/corrosion inhibitor in it. If the system also has a slow leak I can imagine workers regularly topping it up with water only causing it to be over diluted.
Judging from the condition of the radiator the tank the coolant has sediment in it. I'm not sure that they are using antifreeze, can only advise and hope that they are. They say the unit has been in use for 6 months. I can't really say anything for certain. It's used outside of our control. We design them and build them...
Actual specifics of use are a mystery...and obviously I cannot rule out exhaust gas making things acidic... But then why only that piece of the tank?
Can't say I'm completely convinced of what I said earlier, only that it's my best guess so far.
Sounds like we need a sample of water from the radiator next time, I'll make the suggestion for next time.
Makes sense. Aluminum in an application like this is primarily protected from corrosion by the formation of an oxide layer. Keep blasting it away...
Likes Joe591
