What Would Happen if Our Moon Had a Moon?
  • Context: Undergrad
  • Thread starter Thread starter lxXTaCoXxl
    Moon
The discussion explores the hypothetical scenario of what would happen if our Moon had a moon of its own, particularly focusing on the implications for Earth and the dynamics of such a system. Participants consider various aspects of orbital mechanics, stability, and the effects on Earth in this speculative context.
  • One participant suggests that if the Moon had a moon, its mass and size would affect the stability of the orbit, particularly noting that a body of significant mass would have an unstable orbit due to Earth's gravity.
  • Another participant explains that orbits are determined by the center of mass, indicating that if two bodies are of similar size, they would orbit around a point between them, complicating the idea of Earth orbiting the Moon.
  • Concerns are raised about the feasibility of Earth orbiting the Moon, with one participant stating that adjustments to mass could allow for some movement, but the effects would be negligible in everyday life.
  • Discussion includes the concept of Lagrange points and the stability of orbits around the Moon, with specific distances mentioned for stable orbits and the Roche limit for moons.
  • One participant emphasizes that if a moon were to exist around the Moon, it would likely be tidally locked, similar to how our Moon is with Earth, showing only one side to the Moon.
  • Another participant challenges the idea of a large mass orbiting a smaller mass, stating that basic physics laws would need to be altered for this to occur.
Participants express differing views on the plausibility of Earth orbiting the Moon and the stability of a hypothetical moon around the Moon. There is no consensus on the implications of such a scenario, and the discussion remains unresolved regarding the specifics of the dynamics involved.
Participants acknowledge limitations in their hypothetical scenarios, including the dependence on mass and size ratios, as well as the complexities of orbital mechanics that may not align with current physics principles.
lxXTaCoXxl
This is a question I have been pondering for quite some time. I haven't done much research on the matter but I can't find any theories, hypotheses, or explanations of this matter. So I calculate that the best route to take would be to ask those who know about the topic better than myself. I am a student a Full Sail University and I'm getting a degree in Game Design; knowing that 99% of all games do not use true physical systems, I am wanting to keep my game as realistic as possible. I'm developing a game that takes place in outer space in a parallel universe to our own, where our Earth is instead orbiting our moon. Now I know this doesn't seem practical in any way because the Earth's mass relative to the moon's would not allow it to orbit the moon. This is just a big what if type thing and I have made it work by creating a new Earth with the same size but with less density. My question is, what would happen to the Earth in our present universe if our Earth was to switch places with the moon. What would happen if our moon had a moon 1/8 it's size? 1/4 it's size?
Thanks,
Taco
Astronomy news on Phys.org
When dealing with two bodies, the orbits of both are around the center of mass. Earth-moon center of mass is well inside the earth, so that having the moon orbiting the Earth makes sense. If the two bodies are about the same size, the center of mass would be about halfway in between. You can work out the cases you are interested in.
In its orbit, moon accelerates with ~0.0027m/s^2 towards earth. Without precision experiments, you do not notice the orbit at all (even if you stand on the moon) - the other object appears to move around you, unless the rotation is tidally locked (as it is for the moon - if you stand on moon, you always see Earth at a fixed position in the sky).
In this case, you cannot let Earth orbit the moon. You can adjust masses a bit, to give some more movement of Earth itself, but you would not notice the effect in everyday life.
Earth with a significantly reduced mass would be:
- a big ball of water (reduces mass by a factor of ~4 with the same radius)
- significantly smaller
This does not work. Can you describe which visual effects you want to get? Maybe there is a physical solution.
Well I was more of wanting to know the effects on Earth if our moon had a moon about 1/8 it's size, or to go a little bigger; to be about 1/4 it's size. It's an interesting notion to me. As far as the Earth orbiting the moon, I realize that the theory is not even plausible in current physics however, it sounded like a good idea for my game so I made adjustments to make it work. Granted it's not true physics that powers it because the math doesn't allow it. So what would the Earth be like if our moon had a moon? I would like to create a possible scenario to suit this theory for my game.
Thanks,
Taco
A body of that mass would have an unstable orbit due to Earth gravity.
Moon's Lagrange points are ~60000 km away from moon. Stable orbits around the moon have to be smaller, with ~20000km radius as maximum for long-term stability. At the lower side, we have the Roche limit - for a moon-like moon of moon, this is ~2.5 times the radius of moon or ~4300km
Somewhere between those values, moons are possible, I would keep away from the limits to be safe. 1/4 of its size corresponds to 1/64 of its mass, the influence on our tides and so on would be negligible. It would probably be tidally locked to moon: it would always show the same side for moon, similar to our own moon, where we can see one side only.
One body does NOT orbit around another, they both orbit around their mutual center of mass. That's perfectly symmetric. If you are going to have a body of large mass "orbiting" an object of lower mass, you will need to replace some very basic physics laws.
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 33 ·
