What would it take for this to lift a man?
  • Thread starter Thread starter amorphos_b
    Lift
The discussion explores the feasibility of creating a lightweight vehicle capable of lifting a person using advanced materials like graphene and carbonado mesh, powered by a rotary engine similar to that of a Mazda RX7. The focus is on achieving lift through wing design rather than thrust, questioning the necessary wing shape and configuration to generate sufficient lift without relying on thrust momentum. The conversation references biological flight mechanics, such as those of birds and insects, to understand the principles of lift. The inventor seeks to determine the speed and lift required for a manned flight, emphasizing the role of wing aerofoil shape. Overall, the inquiry centers on the intersection of engineering and biological flight principles to achieve human lift.
amorphos_b
What would it take for this to lift a man? Hi, as an inventor i am interested to know what it would take to make one of these ideas lift someone into the air? Let's imagine that it is made of graphene covered carbonado mesh frame, such that it is very light. As for power, let's use a rotory engine e.g. As from the Mazda rx7 ~ because they are small and light + very powerful. Except it will be made from carbonado sphere’s surrounding the piston chamber, which would be as if dropped down into the spheres like a cup.
The entire weight would be majoritively that of fuel, a driver/rider, then the lightwieght vehicle.Is this plausible?Dragonfly simulation; BionicOpter of Festo at the ACHEMA Press Preview Achema_2015
http://www.festo.com/net/nl-be_be/SupportPortal/Details/373260/PressArticle.aspxBird simulation;
SmartBird – Bird flight decipheredhttp://www.festo.com/cms/en_corp/11369.htm_
Without any details of the inventions it is impossible for us to have any idea how to power them.
What i am actually looking for in terms of my invention is; what would it take in terms of speed and lift, to lift a man in terms of wing aerofoil shape alone. I.e. Without thrust momentum. So like how helicopters have blades which are wings but the wings are twisted which gives it thrust momentum. More specifically i am looking at a mass of small wings.I think my query could be answered by asking; how many flies would it take to lift a man?I read somewhere that the flapping of the wings in bird-flight, does nothing, except move the wings back to a position they can push through the air on the next stroke. Thus i am assuming we can remove the up/down motion.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
