What's the acceleration when it contacts the floor?
  • Thread starter Thread starter DR33
    Acceleration
A tennis ball dropped from a height of 5 meters bounces back to 3.2 meters and contacts the floor for 0.036 seconds. The speed just before hitting the ground is calculated using energy conservation, resulting in v_1 = √(10g), while the speed just after the bounce is v_2 = √(6.4g). The acceleration upon contact with the floor is determined by the change in velocity divided by the contact time, yielding an acceleration of 495 m/s². The calculations involve considering the upward direction as positive for velocity changes. This analysis highlights the physics of bouncing balls and the forces involved during impact.
DR33
A tennis ball is dropped from 5m High and bounces back 3.2 m high. It stays in contact with the floor for 0.036 seconds. What's the acceleration when it contacts the floor?
The answer is 495 m/s_². I just don't know how to get to it. thanks so much.
Let v_1 be the speed of the ball just before it hits the ground, and v_2 be the speed just after.
Using energy:
mg(5) = \frac{1}{2} m v_1^2
10g = v_1^2
v_1 = \sqrt{10g}
Also:
mg(3.2) = \frac{1}{2} m v_2^2
6.4g = v_2^2
v_2 = \sqrt{6.4g}
Acceleration is the change in velocity divided by time. (Now consider the up direction to be positive)
a = \frac{\Delta v}{\Delta t}
a = \frac{\sqrt{6.4g} - (-\sqrt{10g})}{0.036}
a = 495 m/s^2
Thx so much.. I really appreciate people helping on other'S request.
thx again
l8er
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
