Can Mathematical Errors Lead to False Equations?
  • Thread starter STEMucator
Well, that's not quite the fallacy invoked. The fallacy invoked in the next step is that ##\sqrt{x^2} = x##. That holds for real x, but not for complex x. The correct equality is ##|\sqrt{x^2}| = |x|##. So, the fallacy invoked is that ##x=y## implies ##\sqrt{x}=sqrt{y}##.The whole thing is a fallacy, but it takes more than one wrong step to get to the fallacy.In conclusion, the original conversation discusses various ways to manipulate equations involving complex numbers, but fails to recognize that certain "rules" do not hold in the complex number system. Specifically, the use of the square
STEMucator
2,076
140
##-1 = -1##
##\frac{1}{-1} = \frac{-1}{1}##
##\sqrt {\frac{1}{-1}} = \sqrt{\frac{-1}{1}}##
##\frac{\sqrt{1}}{\sqrt{-1}} = \frac{\sqrt{-1}}{\sqrt{1}}##
##\sqrt{1} \sqrt{1} = \sqrt{-1} \sqrt{-1}##
##(\sqrt{1})^2 = (\sqrt{-1})^2##
##1 = -1##​
A little teaser I found.
Mathematics news on Phys.org
Basically, what's wrong is that you can't do that. The power laws with which you are familiar are valid only for non-negative real numbers raised to a real power. Those power laws are false for complex numbers such as ##\sqrt {-1}##.
Hard to explain correctly, but when you multiplied you lost one of the roots. Something similar happens when you try to solve some rational equations, in that you obtain both correct solutions and extraneous solutions.
Also, realize that sqrt(1)=-1 or +1.
Given that this was said in response to a post that included multiple instances of ##\sqrt{1}##, I am assuming that you mean to say that ##\sqrt{1}## denotes two different numbers. If that is the case, then I must strenuously and vehemently disagree. It is a convention generally accepted among mathematicians and math educators that, for a positve real numbers ##a##, ##\sqrt{a}## denotes the unique positive solution to the equation ##x^2-a=0## while ##-\sqrt{a}## denotes the negative solution.
I'm trying to more correctly understand what you say.
x^2-1=0
x^2=1
x= +/- sqrt(1)
What a lot of steps you have there
here is the problem
##(\sqrt{-1})^2 \ne \sqrt{(-1)^2}##
It should be clear why.
Squaring has the property (-x)^2=x^2
Square root can only be injective if
-x=x
Since that is only true if x=0 we must conclude square root is not injective elsewhere
Maybe there is some hope. The definition of -1 needs the right variable assigned.
I found this which I am struggling to learn how to accept:
The complex number i is NOT the square root of negative one!
https://www.physicsforums.com/showthread.php?t=637214
Likes 1 person
These math teasers can be fun.
This is the most detailed explanation for sure. I enjoyed it quite a lot.
The blasphemy occurs in the second to last step where I write ##(\sqrt{1})^2 = (\sqrt{-1})^2##. Looking at the line before it, really it should be:
##\sqrt{1 * 1} = \sqrt{-1 * -1}##
##1 = 1##​
No, the "blasphemy" occurs much earlier. Going from ##\frac 1 {-1} = \frac {-1} 1## to ##\sqrt {\frac 1 {-1}} = \sqrt {\frac {-1} 1}## introduces the possibility of an error. Going from that to ##\frac{\sqrt 1}{\sqrt{-1}} = \frac{\sqrt {-1}}{\sqrt 1}## manifests the error. Everything after that is bogus because the error has already been made.
First of all, a clarification should be made on the definition of the square root. One of the most common definitions in complex analysis is this:
[tex]
\sqrt{z} = \sqrt{r}e^{\frac{i\theta}{2}}
[/tex]
when
[tex]
z = re^{i\theta},\quad r\geq 0,\quad -\pi < \theta \leq \pi
[/tex]
Many branches of square root exist, and the choice should always be explained clearly. The one mentioned here is one of the most common, and almost standard IMO. Those who want to use some other definition should make it clear themselves. It makes no sense to use some peculiar definition, and insist that others would have the responsibility to know it.
If you use the definition I just mentioned, then [itex]\sqrt{-1}=i[/itex] precisely correct. I mean it is correct in the sense that the left and right sides represent the same spot on the complex plane [itex]\mathbb{C}[/itex]. In other words, the equation is correct like this
[tex]
(x_1,y_1)=(x_2,y_2)\quad\Longleftrightarrow\quad\Big(x_1=x_2\quad\land \quad y_1=y_2\Big)
[/tex]
So the formula [itex]\sqrt{-1}=i[/itex] is not correct "in a sense" only, but it is actually correct. Use the formula [itex]-1=e^{i\pi}[/itex] and the mentioned definition of the square root.
IMO it is very unfortunate that some people speak about the formula [itex]\sqrt{-1}=i[/itex] holding only "in a sense". Most of the time mathematics is about clear definitions and proved theorems, and not about vague statements about something being "in a sense". Complex numbers are not the only pedagogical failure of course. Infinitesimal differentials are the other infamous ones...
I'm agreeing with gopher_p.
The mapping [itex]z\mapsto \sqrt{z}[/itex] is injective because
[tex]
\sqrt{z_1}=\sqrt{z_2}\quad\implies\quad z_1=z_2
[/tex]
The step
[tex]
z_1=z_2\quad\implies\quad \sqrt{z_1}=\sqrt{z_2}
[/tex]
doesn't look very dangerous to me. Are you suggesting that one might accidentaly apply different branches of square roots on left and right? Certainly some other mistakes are more relevant in the original paradox.
jostpuur said:
The step
[tex]
[/tex]
The standard approach to proving 0=1, 1=-1, etc. involves going from ##a=b## to ##f(a)=f(b)##, and then moving on from there. While that step from ##a=b## to ##f(a)=f(b)## is valid in and of itself, it sure does open the door to fallacies galore.
In this case, the fallacy is invoked on the next step. That ##(ab)^c = a^cb^c## holds when a and b are positive and c is real does not mean that it holds for complex a, b, and c.
x^2-1=0
x^2=1
x= +/- sqrt(1)
The equation ##x^2-1=0## does have two solutions, ##1## and ##-1##. These solutions are called the roots. Taken together, they might even be called the square roots of ##1##. By itself, ##-1## might be called a square root of ##1##.
However if you say "the square root of ##1##" or write ##\sqrt{1}##, the most commonly accepted interpretation of that combination of words and that combination of symbols is that they are used to indicate that the speaker/writer is talking about a single number, ##1##. It's an issue of the language and notation of mathematics, not an issue of the content of mathematics.
I don't like that video one bit. Another bit of pop-math on the YouTubes that serves more to confuse than to educate. In another video, , this same gentleman says that ##\sqrt{64}=8## and specifically says that square roots are always positive. So he is clearly using ##\sqrt{ }## to mean different things in different contexts.
Given a complex number ##c## and no other context with which to interpret it, most mathematicians (I imagine) would take ##\sqrt{c}## to indicate the principle square root of ##c##; the unique complex number ##z## with ##-\frac{\pi}{2}<\arg{z}\leq\frac{\pi}{2}## satisfying ##z^2=c##. In that sense, ##\sqrt{-1}=i## is true.
And while it is probably not appropriate to talk to middle school students (or even most engineering students at college) about principle roots, most students who have been taught the conventional usage of the radix notation for positive reals have no problem accepting ##\sqrt{-1}=i## as a definition of a single "imaginary" number. The problem occurs when they stumble across this issue with ##\sqrt{ab}=\sqrt{a}\sqrt{b}## not working all of the time anymore and we try to sweep it under the rug by (incorrectly) telling them that ##\sqrt{}## is multi-valued or some other nonsense rather than simply telling then that the multiplicative rules for roots unfortunately don't work when negative numbers are involved. My guess is that people want a reason (or want to give a reason) for why it doesn't work, when they really should be trying to understand why it does work for positive numbers.
Then I remain confused, whether I know it or not. The Dr. Tanton video seemed to give a way to reach the correct decision based on saying i^2=-1.
David Copperfield seems to be able to make objects move in ways which violate our current understanding of the laws of physics. But everyone who knows anything about magic knows that it's all smoke and mirrors and misdirection.
The misdirection in this video is the point where he claims that ##\sqrt{(-1)\cdot(-1)}=\sqrt{-1}\cdot\sqrt{-1}##. The smoke and mirrors occurs in the tenuous claim that ##\sqrt{-1}=\pm i## and the gross abuse of the ##\pm## notation. The fact that all of this leads to the conclusion that ##1=\pm-1##, a nonsensical statement if I've ever seen one, should be your first clue that something is not quite right here.
Furthermore, it strikes me as more than a bit odd that he would go through all of this trouble when, by his own logic, he could have just done $$\pm 1=\sqrt{1}=\sqrt{(-1)\cdot(-1)}=\sqrt{-1}\cdot\sqrt{-1}=i\cdot i=-1.$$ Of course, then ##\sqrt{-1}=i## still makes perfect sense and he has no video.
Now I'm not saying that this new argument is valid; in fact, I think it's total bs. But it's at least as valid as his. The bottom line is that you shouldn't, in my opinion, take anything in that video seriously. It's all smoke and mirrors and misdirection, and it's completely devoid of any useful mathematics.
It is the same as,
[itex]
\sqrt{{\(x)}^2}=x
[/itex]
[itex]
\sqrt{{\(-x)}^2}=x
[/itex]
and concludes as x=-x. So we all know the problem?
I can understand this.
What is wrong with this experiment?
This question is often asked when there are unexpected or conflicting results in an experiment. The best way to determine what is wrong is to carefully review the experimental design, procedures, and data to identify any potential errors or sources of bias.
Why are my results not significant?
This question may arise when statistical analysis shows that the results of an experiment are not statistically significant. This could be due to a small sample size, inappropriate statistical tests, or variability in the data. It is important to thoroughly review the data and statistical methods to determine the validity of the results.
What are the limitations of this study?
It is important to acknowledge the limitations of any study, as no experiment is perfect. Common limitations may include sample size, biases, or external factors that could impact the results. Clearly stating these limitations can help provide context for the findings and potential implications.
What is the control group in this experiment?
The control group is a group that does not receive the treatment or intervention being studied. It serves as a baseline for comparison to the experimental group, which receives the treatment. The control group is essential in determining the effectiveness of the treatment and minimizing confounding variables.
How can I improve the validity of my results?
Validity refers to the accuracy and truthfulness of the results. To improve validity, it is important to carefully design the experiment, control for potential biases, and use appropriate statistical methods. It is also helpful to replicate the experiment and compare results with other studies to ensure consistency.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
