When a heap only has 1 node, is that node a leaf?
  • Thread starter Thread starter Of Mike and Men
The discussion revolves around the definition of a leaf node in the context of heaps, particularly when the heap contains only one node. Participants explore different implementations and definitions related to leaf nodes, considering the implications of various indexing conventions in programming languages.
  • One participant suggests that using the condition (2*i+1 >= n) is more consistent with the definition of a leaf node, especially when considering the root node in a single-node heap.
  • Another participant agrees that a root with no children should be considered a leaf, indicating that this perspective aligns with their understanding of tree structures.
  • A participant notes that the programming language being used (C++) could affect the interpretation of indices, as some languages start indexing at 1 instead of 0.
  • One participant elaborates on the binary heap structure, explaining the assignment of indices for nodes and children, and emphasizes that a node is defined as a leaf if it has no children.
  • Another participant raises a theoretical concern about calling the root node a leaf, arguing that it lacks a parent node, which complicates the definition.
Participants express differing views on whether a single-node heap should have its root classified as a leaf. While some agree with the classification, others challenge this notion based on theoretical considerations, leading to an unresolved discussion.
There are assumptions regarding the indexing conventions in programming languages that may influence the definitions and interpretations of leaf nodes. Additionally, the discussion does not resolve the implications of these definitions on algorithms that operate on heaps.
Of Mike and Men
Hey all,
So, I'm working on heaps, and looking at various implementations of heaps, I find that a lot of people us bool returning function for return (2*i+1 > n), where i is an index of a node stored in an array, and n is the size of the array. (2*i+1 is the formula to get the left child's position in the array). The function returns true if it is a leaf, false if it is not a leaf.
However, doesn't using 2*i+1 >= n make more sense? The case of 2*i+1 > n doesn't cover if i is your root node (IE 0), and n is only 1. Since 2(0)+1 = 1 > 1 returns false. Also by definition a node is a leaf if it has no children. I know this is kind of a special case, but it seems to be more consistent with definition of a leaf.
I guess I'm a little confused on what the proper definition would be symbolically.
Technology news on Phys.org
What language are you programming in? Some languages start at index 1, not zero. It's possible that your definition was for that kind of language.
Yes, in my opinion, a root with nothing beneath it is also a leaf.
C++ sorry, I should’ve included that in the OP. I see that assuming root with no children is a leaf, that it can cause issues with various algorithms (IE needing to check when there’s only 1 item in the heap as well as checking whether or not it’s a leaf in pop), so maybe it’s just for reducing the lines of code? But it seems irrelevant since it’d be constant time.
The notion of a binary heap is based on the notion of a complete binary tree. You can assign the root an index #i = 1#. Then if some node has been assigned the index ##i##, you assign its left child the index ##2i## and assign its right child ##2i + 1##, if such child exists for each case. Then the tree is complete iff the set of assigned indices is a contiguous set. Now, in order to make the representation of a complete binary tree be contiguous starting at 0 you assign left child ##2i + 1## and the right child ##2i + 2##.
Yes, but if it is the only node and is also at the top of the heap i.e. has no parents, it is called the root node. From a theoretical standpoint, it does not make much sense to call it a leaf because in this way there is no parent node.
