When and Why Was the Definition of the Meter Changed?
  • Context: Graduate
  • Thread starter Thread starter pervect
    Definition Meter Si
101 replies · 13K views
HallsofIvy said:
The "radian measure" of an angle is defined as the length of the arc cut off by that angle with vertex at the center of a circle of radius r, divided by r. The numerator and denominator are both linear measurements with the same linear units. The ratio is dimensionless. That is why radians are (and should be) dimensionless.
This is the SI convention, but it is not the only convention possible. The angle in some system of units is not necessarily equal to the ratio, but in general it is proportional to the ratio: ##\theta = k \frac{s}{r}##. For radians k is a dimensionless 1 making radians dimensionless, but for degrees ##k=180^{\circ}/\pi## which could be considered dimensionful if degrees were given a dimension. Hence the dimensionality of angles is a convention. SI could have chosen k to be a dimensionful 1 rather than a dimensionless 1.
on Phys.org
PAllen said:
, it would take a bit more than a million times the age of the universe to produce a mole of oranges.
But in 2008-2009 Zimbabwe was able to produce a mole of Zimbabwe dollars overnight.
HallsofIvy said:
"Degrees"? What in the world are "degrees"? Every one knows that radians are the only way to measure angles!
That's somewhat amusing - I am assuming that it was intended to be, of course.
But, being serious, I do have to say that people do use degrees. We can generalize this by saying that a statement that starts with "Every one knows" is generally false, usually there is someone that doesn't know something, and/or is willing to argue some particular point.
Exactly what to replace a statement about "what everyone knows" with is somewhat unclear.
Once we are listing our pet peeves with the SI, here is mine: I think it's awful that Avogadro's number is now an arbitrarily chosen constant. This number, or rather its reciprocal, once represented an important physical quantity: the mass of a baryon in grams. Of course both "baryon" and "gram" require further specification, but the choice of Carbon-12 selects the baryons in a satisfactory way, and we had just gotten around to a solid definition of the gram. So Avogadro's number should be an experimental fact, not open to definition by fiat.
If they would have gone the other way and set a number for ##N_A## while keeping the Carbon-12 standard, thereby defining the gram and kilogram, I would be happy with that too. But fixing both the kilogram and the mole numerically removes the physical meaning of the mole/amu/Avogadro number, and so makes the system more arbitrary rather than less.
Of course, I am also offended that they used ##h## rather than ##\hbar## for the kilogram definition. Can you imagine, ##\hbar## is now an irrational number!
We can now write the mass of a baryon directly in the new kilogram standard. Why does Avogadro’s number need to be tied to the mass of a baryon?
Of course it doesn't need to be. But it pains me that something that once had physical meaning has been redefined as a mere convention.
The mole is not just "some big number that we divide our quantities by to make them manageable". It is the conversion factor between amu and grams, and amu is/was (a more rigorous form of) "number of baryons". The new definitions lose contact with that structure.
The mass difference between different nucleons (not to speak of baryons in general) and even between the mass for the same nucleon in different nuclei is far greater than the deviations of the true mass of N_A C-12 atoms from 12g. Hence, I don't see a problem here.
The SI didn't knowingly change the values of any of the units, so I expect that the mass of 1 mol of Carbon-12 is still exactly 12g, to within current measurement accuracy. What bothers me is that this fact no longer play any definitional role.
I think that as much as possible, units should be values with specific physical relevance. Of course we are limited by the need to keep fixed the values currently in use, so we are forced to use large, ugly multiples of the physical values. The mole was the one case where the old value actually did have significance, and they went and stuck in a big ugly number anyway!
As far as I know none of the SI units satisfy that criterion. I think only natural units would.
They don't now, but they were originally intended to. The metre was ##10^{-7}## times the length of a curve from the Earth's equator to its north pole. The gram was the mass of a cubic centimeter of water at standard atmospheric pressure and freezing temperature. And the (older) second, of course, was ##\frac 1{24\times 60\times 60}## of the Earth's mean solar day.
The ideal of choosing units based on Nature is what gave us the SI in the first place. Unfortunately the old definitions failed, due to the values involved not being truly fixed nor easy to measure, and the newer definitions were constrained to be equal to the old ones in value. if we were creating new units today, we would probably use natural units times powers of ten, and perhaps the Cesium hyperfine transition frequency times a power of ten. We certainly would not use numbers like 299,792,458!
Honestly, those were horrible definitions as they relied on arbitrary artefacts and resulted in units that were not very well defined.
Of course we know they didn't work well, and perhaps people should have foreseen that. But the motive was to make the units as non-arbitrary as possible, and I think that's still an admirable ideal.
And yes, nowadays our perspective is so broad that we think of the planet Earth as an "arbitrary artifact". So much the better!
To argue that the 'Mole' is not dimensionless is like arguing that the number 1 is not dimensionless, because you have to have one of something?
Errr... no, not really.
A Mole is dimensionless, whereas a mole of [something] has the dimension [something].
No, they don't. All they do is make the conversion factor exact.
If you had an apparatus that you used to measure the conversion factor you would continue to use the same apparatus in the same way. It's just that the apparatus now calibrates rather than measures. There's nothing less physical about that.
maline said:
They don't now, but they were originally intended to. ...
You and I have very different opinions on what constitutes a physically meaningful quantity. To me all of those quantities you have identified as being physically meaningful are not, while the fundamental constants of nature are physically meaningful.
I mean, the mass of a cubic centimeter of water is only physically meaningful to me if I am weighing a volume of water. Planck’s constant is physically meaningful then, but it is also physically meaningful if I am measuring other things besides a volume of water.
I think the idea was to define the gram in terms of the centimeter, with the conversion factor being the most "natural" density available. Pure water was seen as the archetypical 'measurable substance".
I probably don't disagree with you on most of those judgements. The difference is the difference in perspective between the eighteenth and twenty-first centuries. Things like the details of our planet, or the freezing point of water, were once seen as primal and indispensable elements of Reality. Nowadays we know a bit more about with things are truly fundamental, so the old Tremendously Important Facts have become contingent bits of trivia.
My point is the ideal that I think they were aiming for with these definitions: to describe our quantities relative to fundamental aspects of Nature, with a minimum of arbitrary choice. I admire that goal, and I think that the old definition of Avogadro's number was the last piece of the SI to still exemplify that, without the ugly numbers.
The entire point of the "ugly" numbers is to ensure that all of the archaic definitions hold to measurement accuracy (or at least very close to it). As such, those "ugly" numbers appear as a relic of the old definitions.
The main point of the definitions is to make the units as well defined as possible, thus referring to measurements with as little measurement uncertainty as possible (and also not subject to changes over time as artefacts are prone to).
Avagadro's Number looks a lot less ugly to me now than it did before. Now it's an integer. It used to have an uncertainty to it, that seems more ugly to me.
Orodruin said:
Note: If we wanted "nice" numbers, then we would probably define a reasonably sized length unit such that the speed of light would be ##10^9## of that length unit per second ... Oh wait! That is within 2% of a foot, can't have that ...
Bwa Ha Ha! You caught on to my sinister plot for Imperial supremacy!
Well yes... meaningful quantitative statements do tend to have uncertainty... only tautological ones don't.
I prefer 'Avogadro's Constant (Na) = 6.022E23/mol
the "mole" is not defined as a number; it is defined as an 'amount of substance' (symbol, n)
and 1 mol of anything is the amount of that thing that has 6E22 entities.
Somebody mentioned that the mole is a conversion unit. It surely is. It is a miracle constant. It instantly converts atomic mass numbers into grams. From the micro world to the macro world. What is the value of this constant? Who gives a damn'? (OK, it's the inverse of the atomic mass unit expressed in grams)
If the value of Avogadro's constant were 42/mol, a chemist's life would be horrible. The poor chemist would have to deal with one number if he/she is thinking about atoms and molecules, and a different number if he/she were in the lab with bottles of stuff. It doesn't bear thinking about.
You should update your notion of how the SI defined today. Don't worry, the change officially got into effect only in May this year :-).
Orodruin said:
Nobody has said otherwise. It has been argued that it would be more natural to define it as a number or symbol.
But it IS defined as a number:
The mole, symbol mol, is the SI unit of amount of substance. One mole contains exactly ##6.02214076 \cdot 10^{23}## elementary entities. This number is the fixed numerical value of the Avogadro constant, NA, when expressed in the unit ##\text{mol}^{−1}## and is called the Avogadro number.[7][49] The amount of substance, symbol n, of a system is a measure of the number of specified elementary entities. An elementary entity may be an atom, a molecule, an ion, an electron, any other particle or specified group of particles.
For details about the new SI, see the Wikipedia article
https://en.wikipedia.org/wiki/2019_redefinition_of_the_SI_base_units
It is not defined as a number in the sense we typically use in the meaning of having no physical dimension. Although the Avogadro number is defined by its numerical value and represents the number of entities in a mole by definition, amount of substance (and hence the unit mole) has its own physical dimension within SI. A mole is therefore not dimensionless and neither is Avogadro's number (even if it is called "number").
The argument that some (including myself) have made in this thread is that it would be more natural not to give substance amount its own physical dimension and having the mole be a symbol like % or making it actually represent a dimensionless number (which would in essence be ##N_A##).
Edit: The physical dimensions of the base units are also discussed in the SI brochure section 2.3.3:
Physical quantities can be organized in a system of dimensions, where the system used is decided by convention. Each of the seven base quantities used in the SI is regarded as having its own dimension.
It is clear from this that the mole (which is a unit of the base quantity amount of substance) has non-trivial physical dimension and therefore is not just a number under the current SI definition. The argument made here is that it would be more natural to define it as being dimensionless.
The SI is not supposed to provide "natural units" but well-defined precise units that can be reproduced everywhere (by assumption of the cosmological principle even everywhere in the entire universe) to be used FAPP under everyday circumstances.
According to the definition 1 mole is the amount of substance consisting of a specific number of entities (relevant degrees of freedom I'd translate it). That's why the Avogradro number in the SI has the dimension 1/mol, i.e., you have ##\simeq 6 \cdot 10^{23}## entities per mole.
