mrcotton
- 120
A current flows in vertical square coil whose plane is at right angles to a horizontal uniform magnetic field B. The coil can rotate about a vertical axis.
Which is correct
A) The forces on the two vertical sides are equal and opposite.
B) A couple acts on the coil
C) No forces act on the horizontal sides of the coil
D) If the coil is turned through a small angle about the vertical it will remain in position.
The answer in the mark scheme is A
What I can't seem to see is why B is not true also. Why are these two equal and opposite forces about an axis not causing a couple?
Any help greatefully received
