How Do You Find the Limit When L'Hopital's Rule Fails?
In summary, L'Hopital's Rule is a mathematical rule used to evaluate limits of indeterminate forms. It states that if the limit of the ratio of two functions is indeterminate, then it is equal to the limit of the ratio of the derivatives of those functions. However, this rule fails to apply when the limit of the ratio of the derivatives is also indeterminate, which can happen when the derivatives of the functions are equal to zero or when they both approach infinity at the same rate. In these cases, other techniques such as factoring, substitution, or trigonometric identities can be used to solve the limit. L'Hopital's Rule is not always necessary and may not be applicable in certain cases, such as with discrete
niyati
63
I'm suppose to find the limit as x goes to infinity of [(9x + 1) ^ (1/2)] / [(x+1) ^ (1/2)].
L'Hopital's Rule does not work on here (it said so even in the directions) as the function keeps on cycling.
...they gave us the answer (3) but I need to find out how.
:S
Nevermind.
Figured it out.
:DDD
When L'Hopital's Rule fails, it means that the limit cannot be solved using the rule. This usually happens when both the numerator and denominator approach infinity or zero at the same time, resulting in an indeterminate form of "infinity over infinity" or "zero over zero". In this case, L'Hopital's Rule cannot be applied and we need to use other methods to find the limit.
In the given function, both the numerator and denominator approach infinity as x goes to infinity, resulting in an indeterminate form. Therefore, L'Hopital's Rule cannot be used. However, we can still solve for the limit by simplifying the function.
First, we can rewrite the function as (9x + 1)^(1/2) / (x + 1)^(1/2) = [9 + (1/x)]^(1/2) / [1 + (1/x)]^(1/2). As x approaches infinity, both 1/x and 1/x^2 approach zero, so we can ignore them in the function.
This leaves us with (9)^(1/2) / (1)^(1/2) = 3 as the limit as x approaches infinity. Therefore, the limit of the given function is 3.
Related to How Do You Find the Limit When L'Hopital's Rule Fails?
1. What is L'Hopital's Rule?
L'Hopital's Rule is a mathematical rule used to evaluate limits of indeterminate forms, where both the numerator and denominator approach zero or infinity. It states that if the limit of the ratio of two functions is indeterminate, then it is equal to the limit of the ratio of the derivatives of those functions.
2. When does L'Hopital's Rule fail to apply?
L'Hopital's Rule fails to apply when the limit of the ratio of the derivatives of two functions is also indeterminate. This can happen when the derivatives of the functions are equal to zero or when they both approach infinity at the same rate.
3. What are some common examples of indeterminate forms where L'Hopital's Rule fails?
Some common examples include limits of the form 0/0, ∞/∞, 0⋅∞, and ∞-∞.
4. How can I solve limits where L'Hopital's Rule fails to apply?
If L'Hopital's Rule fails to apply, you can try rewriting the expression or using other limit-solving techniques such as factoring, substitution, or trigonometric identities. In some cases, the limit may not exist.
5. Is it always necessary to use L'Hopital's Rule to solve limits?
No, L'Hopital's Rule is just one of many tools that can be used to solve limits. It is not always necessary and may not be applicable in certain cases, such as when dealing with discrete functions or limits involving irrational numbers.
  • Calculus
  • Calculus
