When light goes from air to water,it change direction.
Light changes direction when transitioning from air to water due to refraction, a phenomenon resulting from the interaction of photons with water atoms. Refraction occurs at the boundary between two different media, affecting the behavior of electromagnetic waves. Understanding this requires a shift in perspective about photons, which are not simply particles moving through space. The discussion emphasizes the importance of grasping the true nature of photons for a deeper understanding of light behavior. For a comprehensive explanation, Richard Feynman's "QED: The Strange Theory of Light and Matter" is recommended.
Hepic
When light goes from air to water,it change direction. Thas is because phtons interact with atoms of water. But what happened and they change direction??(refraction)
Science news on Phys.org
Refraction is a wave phenomenon - it's easiest to understand by analyzing the behavior of an electromagnetic wave passing through the boundary between the air and the water.
To understand refraction in terms of photons, the first step is to forget everything you think you know about photons :smile: and get rid of the picture implied by your question: photons aren't like little bullets moving through space, and when a beam of light changes direction by reflection or refraction, it's not because a whole bunch of photons changed direction. Once you've forgotten everything you think you know about photons, you're ready to learn how they really behave, and for that I highly recommend Feynman's "QED: The strange theory of light and matter".
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
