When will these cars pass eachother - kinematics
  • Thread starter Thread starter teng125
    Cars Kinematics
Car A starts from rest and accelerates at a constant rate, while Car B travels at a constant speed before decelerating. The two cars pass each other at a distance of 90 meters, with their speeds equal at that point. The acceleration of Car A is determined to be 3.59 m/s². To solve for the acceleration, equations for the velocities and positions of both cars are established, leading to a system of equations that can be solved for the unknowns. The discussion emphasizes the importance of correctly applying kinematic equations to find the solution.
teng125
Car A with u=0/s is on the northbound land of a highway and car B is traveling in th southbound lane at constant u=26.67m/s.At t=0 , A starts and accelerates at a constant rate a(A) . while at t=5 , B decelerates with constant magnitude of a(A)/6 . knowing that when the two carspass each other at x=90m , and v(A) = v(B),determine acceleration of car A.
i have tried it many times but stil can't ind the answer.pls help.
the answer is 3.59m/s^2
thanx
oh...the length between the two cars is d in which we have to find in the second part
You just need to write the equations of velocity and movement of each car. Then you'll find out the answer[/color]
for v(A)=180a(A)--------1
s(A)=1/2 at^2--------2
v(B)=26.67 - 0.5a(B)t--------3
d-90=26.67t - 0.5a(B)t^2-----4
is it rite??
pls help...
pls help...
teng125 said:
pls help...
Teng! I'm not a moderator but all you have to do is ask ONCE!
Tricky! I like it.
In the following, I have defined + to be Northward.
For car A: Car A starts at position x_{0A} at a speed of v_{0A} = 0m/s with an acceleration of a(A).
x_A=x_{0A}+v_{0A}t+(1/2)a_At^2; v_A=v_{0A}+a_At
x_A=x_{0A}+(1/2)a(A)t^2; v_A=a(A)t
For car B: Car B starts at position x_{0B} at a speed of v_{0B} = -26.67 m/s with an acceleration of -(1/6)a(A).
x_B=x_{0B}+v_{0B}t+(1/2)a_Bt^2; v_B=v_{0B}+a_Bt
x_B=x_{0B}-26.67t-(1/12)a(A)t^2; v_A=-26.67-(1/6)a(A)t
Now, at x=90 m, both cars pass each other and have the same speed. We don't have a specific equation to find t or a(A), but we have two equations we can write. First, at time t both cars have the same speed. Thus at (90 m, t):
a(A)t=-26.67-(1/6)a(A)t
Second, both cars are at the same point at this time, so:
x_{0A}+(1.2)a(A)t^2=x_{0B}-26.67t-(1/12)a(A)t^2 =90 m
(This last is actually THREE equations. Both distances are equal to 90 m as well as each other.)
You've got four equations in four unknowns, so you should be able to solve the system.
-Dan
