Where can I find the signal detection point on a SatFinder WS-6903?
  • Thread starter Thread starter Ravaner
The discussion focuses on locating the detected signal point on the SatFinder WS-6903 for use in a radiotelescope application. The user seeks schematics or guidance on tapping the signal before it is digitized and displayed. Challenges include the complexity of the device with numerous SMD components and a microcontroller. The user specifically needs the amplitude of the signal for automatic gain control (AGC) purposes. Overall, experienced insights or schematics for this model are requested to facilitate the task.
Ravaner
Hello. In a radiotelescope application I need to get the detected signal in a SatFinder WS-6903. probably just before digitizing and display. If someone owns the schematics or knows where is this point on PCB ...
At those frequencies, I doubt there is a point where you can easily tap off a signal. Do they make any versions with a USB interface or some other way to communicate with the microprocessor inside?
Hi. In fact I did that job already on more classical sat finder with analog display (µ amp meter) . This one is more complicated, with many smd and double face components. Finally it's always the same chain :filtering, voltage doubling (Schottky diodes), amplification, display. I really need an experienced reply for this device, or better the schematics.
I need to get the detected signal...
are you after the signal content or just its amplitude as in AGC ?
Hi. I only need its amplitude, as I wrote it's a simple detection (AGC is a good example). Problem is that on my new sat finder WS-6903 there are to many components (µcontroller ...) and to find the place of this signal is not an easy game to play
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
