Where Does Electromagnetic Energy Go?
When an electric bulb is switched off, the electromagnetic energy it emitted does not disappear; instead, it is absorbed by surrounding objects. This energy transfer results in the energy being stored as thermal energy, which is associated with the movement of atoms in those objects. The principle of conservation of energy confirms that energy can neither be created nor destroyed, only transformed. Thus, the transition from electromagnetic waves to thermal energy explains the phenomenon of darkness following the bulb's shutdown. Understanding this process highlights the fundamental nature of energy transformation in physics.
mak_phy
Hi all physics lovers,
please bear with my question as its like a kid wondering about something :)
Energy can neither be created nor be destroyed. So when I switch off an electric bulb, there is darkness. So where does the electromagnetic energy go? :confused:
Thank you.
Science news on Phys.org
It gets absorbed by objects in the room. The energy goes from electromagnetic waves to being stored in the jiggling of atoms.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
