B Where is all the places that QM and SR/GR disagree?
  • B
  • Thread starter Thread starter member 620756
    Qm
member 620756
Im very misinformed on this,and I was struggling whether to put this in the Quantum section,or Relativity.Please don't use advanced mathematics,and put everything into simple words for me,I can understand a bit of physics vocabulary so that is okay.
QM and SR aren't in conflict. The problem is with GR, and then it's not so much that they disagree as that neither one works everywhere. Quantum mechanics and its extension to quantum field theories work just fine in any problem in which the gravitational effects are small. General relativity works just fine in any problem in which the quantum mechanical effects are small. But we still don't have a completely satisfactory theory that works when neither the gravitational nor the quantum effects are small - for example, near the "center" of a black hole.
The specific places they disagree require higher maths to appreciate - it is not that they cannot be phrased just using English but that it is too easy to misunderstand the normal-language version. That is why we use maths, and why we have jargon. Just try explaining Newton's Laws of motion to a five-year-old using only words they understand.
So what is your education level?
Bearing that in ind, I can give you a basic, in a nutshell, idea of where the conflicts arise.
There are four fundamental forces in classical mechanics ... these are: electromagnetic, strong nuclear, weak nuclear, and gravitational.
QM gives us Quantum Field Theory which gives us the Standard Model of Particle Physics ... this models the fundamental forces as interactions between particles, the forces themselves, the rules you may be used to from secondary school, are what happens on average over a very large number of these interactions. In this picture, the laws of physics are statistical - lots of randomness and things happening with no cause, though cause and effect do happen.
GR models gravity as a pseudoforce emerging from the curvature of space-time associated with the distribution of energy. Much like the centrifugal force is a pseudoforce arising from rotation. Mass happens to be a very high concentration of energy so it has a strong effect on the appearance of gravity. In this picture, forces could be described as a form of geometry - and the laws of physics are deterministic in the sense that cause and effect is an illusion created by our relationship with the dimension of time.
See how these two pictures are fundamentally at odds with each other?
This is by no means complete.
A more detailed answer would need extra information, like your education level and what you want the answer for.
Like: do I suggest MIT open courseware lectures? There is a very good series on how classical mechanics works, for example. But if your physics is at the junior secondary school level there is no point.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
