Where is the mass in a black hole?
  • Context: Undergrad
  • Thread starter Thread starter snorkack
The discussion revolves around the nature of mass in black holes, specifically focusing on Schwarzschild black holes. Participants explore whether these black holes can be conceptualized as entirely vacuum or if they contain mass at the singularity. The conversation includes theoretical implications, mathematical descriptions, and the nature of singularities.
  • Some participants propose that the Schwarzschild black hole is best conceptualized as entirely vacuum, with no matter present, while others argue that it may contain a point mass at the singularity, which is described as extraordinary matter.
  • It is noted that the singularity is not a point but rather a space-like line or hypersurface, leading to differing interpretations of its dimensionality.
  • Some participants assert that the singularity is not part of the manifold and that it represents a limit of the theory, indicating a lack of answers for certain questions regarding mass and singularities.
  • There is a distinction made between the Schwarzschild black hole as a vacuum solution to Einstein's equations and its application to describe the spacetime outside a spherically symmetric mass.
  • One participant mentions that while the Schwarzschild solution describes the vacuum outside a mass, it does not imply the presence of a singularity in that vacuum region.
  • There is speculation about what occurs below the event horizon of a black hole, with some suggesting that current theories lead to a singularity at r = 0, while others propose that a theory of quantum gravity may provide a more complete description.
Participants express multiple competing views regarding the nature of mass in black holes and the interpretation of singularities. The discussion remains unresolved, with no consensus reached on whether mass exists at the singularity or how it should be conceptualized.
Limitations include unresolved mathematical steps regarding the nature of singularities and the implications of vacuum solutions. The discussion also highlights the dependence on definitions and interpretations of terms like "mass" and "singularity."
snorkack
snorkack said:
Are you sure that Schwarzschild black hole is best conceptualized as entirely vacuum, with no matter anywhere, rather than as a point mass at the point singularity, which is not quite ordinary matter but may count as extraordinary matter?
Yes. The singularity is not a point (mass or otherwise), it's a space-like line that lies in the future of all worldlines entering the hole.
Yes. That's what the actual math says.
No. That is not what the actual math says.
snorkack said:
[This thread started as a hijack of https://www.physicsforums.com/threads/confusion-regarding-black-hole-spin.1079871/#post-7256289]
The Schwarzschild spacetime is the unique spherically symmetric vacuum spacetime.
Because it is the unique spherically symmetric vacuum spacetime, it does represent the spacetime in the vacuum outside of a spherically symmetric mass. So there are spacetimes that can be thought of as the Swarzschild spacetime surrounding matter.
But the maximally extended Schwarzschild spacetime cannot be understood that way. It is vacuum everywhere. It does not surround a singularity. It has a pair of singularities, one in the future and one in the past.
Just to be clear, there will be no singularity anywhere in such a spacetime, and the vacuum region will correspond to Schwarzschild spacetime outside of some areal radius ##r## (the areal radius of the surface of the matter), which must be at least 9/8 of the Schwarzschild radius corresponding to the mass of the matter.
Isn't it a space-like hypersurface?
Surfaces of constant ##r## are hypercylinders of infinite length and cross-sectional area proportional to ##r^2##. As ##r\rightarrow 0## the cross-sectional area goes to zero, which I would say means it is more like a 1d line than a surface. It's the singularity, though, so a 3d surface where two of the dimensions have zero extent is probably just as good a description...
As Peter pointed out the singularity is not part of the manifold, and singularities are the mathematical equivalent of "here be dragons" anyway. So mathematical descriptions may well not be as precise and unique as normal.
It isn't anything like a point in space, anyway, which would be a timelike line.
-GR black holes are typically vacuum solutions
-Being a vacuum solution to Einstein's equations means that stress-energy tensor is equal to zero. There is no matter anywhere, but there is curvature.
-A singularity in physics is the theory saying "you're asking me questions I'm not ready to answer".
-"Mass (or matter) is hidden in the singularity" is like saying that mass (or matter) is nowhere; the singularity is not just another point in the universe. Is not a point and it's not part of the manifold.
I would put things in slightly more sober terms:
1) There is a vacuum solution to the EFE (Einstein Field equations), which is characterised by a parameter ##M##, and is known as a Schwarzschild Black Hole. There is no stress-energy anywhere, although there is a singularity at ##r = 0##.
2) The Schwarzschild Black Hole can also be used to describe the spacetime outside a spherically symmetric (non-spinning) object - but only outside the surface of the object. I.e. not all the way to ##r = 0##.
3) If a star is sufficiently massive, then as it runs out of fuel, it will collapse and form a Schwarzschild black hole and an event horizon at the characteristic Schwarzschild radius. Although some of the star's mass will have been ejected in the collapse (supernova explosion), much of it will disappear below the event horizon.
4) What happens below the event horizon is a matter of conjecture. There is no known force that could resist the complete gravitational collapse of the star, which means the current theory of GR leads to a singularity at ##r = 0## and an incomplete description of what happens to the mass.
5) Alternatively, a theory of quantum gravity may describe more fully what happens to the mass of a collapsed star below the event horizon.
  • · Replies 22 ·
  • · Replies 43 ·
  • · Replies 51 ·
  • · Replies 57 ·
  • · Replies 114 ·
10K
