- 37,005
- 16,006
Why would you need to define it mathematically? We are doing science, not math.etotheipi said:Accelerometers are a nice heuristic, but you can't really define an accelerometer mathematically.
Then you have a problem. Ultimately, all the maths we do is supposed to support predictions like "if the dial on this machine reads ##x\pm \delta x## units then the dial on that machine will read ##y\pm \delta y## units". If it's not capable of doing that, what's it got to do with the real world?etotheipi said:accelerometers are a nice heuristic, but you can't really define an accelerometer mathematically.
I 100% disagree with this. In my opinion not only are operational definitions necessary for science, they are the most important ones.etotheipi said:I still don't think one should be using mythical objects such as accelerometers in definitions of physical quantities
Agreed. Why do you need to define it mathematically if you can just buy one?Dale said:Why would you need to define it mathematically?
Which means the theory has to be capable of predicting what the accelerometer will read; which means there has to be some theoretical entity that corresponds to that prediction. So call whatever that theoretical entity is in classical (non-relativistic) mechanics "proper acceleration" and you're done.etotheipi said:an accelerometer is something physical which is described by the theory
Ah, but that theoretical entity corresponding to it via the inverse physical map, which I'll light-heartedly call ##\mathcal{P}^{-1}## for fun, is precisely ##\mathbf{a} \big{|}_K##! It is nothing but the acceleration with respect to an inertial reference system.PeterDonis said:Which means the theory has to be capable of predicting what the accelerometer will read; which means there has to be some theoretical entity that corresponds to that prediction. So call whatever that theoretical entity is in classical (non-relativistic) mechanics "proper acceleration" and you're done.
Ok, then call that "proper acceleration". What's the problem?etotheipi said:that theoretical entity corresponding to it via the inverse physical map, which I'll light-heartedly call ##\mathcal{P}^{-1}## for fun, is precisely ##\mathbf{a} \big{|}_K##! It is nothing but the acceleration with respect to an inertial reference system.
That's exactly it - what others here are referring to as 'proper acceleration' is nothing but a special case of co-ordinate acceleration in classical mechanics (as opposed, however, to relativistic theories). There's no need for this extra terminology:PeterDonis said:Ok, then call that "proper acceleration". What's the problem?
etotheipi said:The point I'm making is that I haven't really noticed any classical mechanics textbooks use 'proper acceleration', and there isn't particularly a need to introduce it.
I can see at least two good reasons to have it:etotheipi said:There's no need for this extra terminology
Actually, there is one important case where this is not true: in classical mechanics (as opposed to relativity), gravity is a force. So in classical mechanics, the acceleration of a rock dropped from a height above the surface of the Earth is coordinate acceleration in an inertial frame (because the frame in which the surface of the Earth is at rest is an inertial frame), so it would qualify as "proper acceleration" under the correspondence suggested in posts #38 and #39. But in relativity, it isn't.etotheipi said:What others here are referring to as 'proper acceleration' is nothing but a special case of co-ordinate acceleration in classical mechanics
Measurement devices are not mythical, but the real-world equipment we use to observe the world quantitatively and only this operational definition of observables enables us to relate the mathematical descriptions of our beloved theories with the observed phenomena in Nature.etotheipi said:Classical mechanics, especially, is very much a mathematical structure. There are many applied mathematics texts on the subject, e.g. Abraham/Marsden, Spivak, Arnold, et cetera. I'm not a mathematician myself, but I still don't think one should be using mythical objects such as accelerometers in definitions of physical quantities![]()
Right, sure, but everything I've been saying in this thread is justified by the assumption of sticking well within the realm of classical physics, so here gravity well and truly is a force ##- \nabla \varphi##PeterDonis said:Actually, there is one important case where this is not true: in classical mechanics (as opposed to relativity), gravity is a force. So in classical mechanics, the acceleration of a rock dropped from a height above the surface of the Earth is proper acceleration (because the frame in which the surface of the Earth is at rest is an inertial frame). But in relativity, it isn't.
And note that in this case, the mathematical entity in the theory that corresponds to the actual accelerometer reading is not ##\mathbf{a} \big{|}_K##, because that is nonzero, but the accelerometer reading for an accelerometer attached to the rock is zero.
There is no single definition for the ordinary language word "time" in relativity. The two most common meanings are "coordinate time" (which requires choosing a coordinate chart, and which at least strongly implies that the coordinate you are labeling as "time" is timelike) and "proper time" (which requires choosing a timelike curve). Your "scalar field" and "curve parameter" definitions correspond to these two cases.etotheipi said:here's another example from special relativity: what is time?
Which is true for the "proper time" (curve parameter) definition: the clock measures proper time along its worldline.etotheipi said:It's often also said that "time is what a clock measures".
It doesn't; "time is what a clock measures" is what defines a clock, just as you suggest, not what defines time.etotheipi said:the clock, as a physical device, really ought not to factor into the definition of time!
@etotheipi gave the answer in post #2. Acceleration is measured with respect to an inertial frame, but you can show that the answer is the same in all inertial frames.feynman1 said:I don't understand why the acceleration can be invariant. Aren't all kinematic quantities measured w.r.t a reference frame? Then the magnitude of the acceleration should also be relative to some frame?
Emphasis added.etotheipi said:'proper acceleration' is nothing but a special case of co-ordinate acceleration in classical mechanics
No. Classical mechanics is fundamentally a scientific theory that uses those mathematical structures to make accurate predictions of classical physics experiments. You cannot remove the connection to experiment and still claim to be doing classical mechanics. Hence operational definitions are essential to the theory. Those operational definitions are precisely what make it classical mechanics instead of just symplectic geometry etc.etotheipi said:Classical mechanics is fundamentally a mathematical structure, a study of certain differential equations, differential and symplectic geometry, et cetera.
Of course, there is more than one way to formulate classical mechanics. With the Newton Cartan formulation of Newtonian gravity you get the relativistic definitions of inertial frames, the equivalence principle, and you can consider gravity to be a fictitious force in a local inertial frame. It is a little cumbersome to actually use, but it is nice to know that these specific good features of GR are “backwards compatible”.PeterDonis said:in classical mechanics (as opposed to relativity), gravity is a force. So in classical mechanics, the acceleration of a rock dropped from a height above the surface of the Earth is coordinate acceleration in an inertial frame (because the frame in which the surface of the Earth is at rest is an inertial frame), so it would qualify as "proper acceleration" under the correspondence suggested in posts #38 and #39. But in relativity, it isn't.
This is personal preferenceDale said:No. Classical mechanics is fundamentally a scientific theory that uses those mathematical structures to make accurate predictions of classical physics experiments. You cannot remove the connection to experiment and still claim to be doing classical mechanics. Hence operational definitions are essential to the theory. Those operational definitions are precisely what make it classical mechanics instead of just symplectic geometry etc.
How do you know 'making sense' would still be the same?etotheipi said:If, overnight, the laws of Physics were to suddenly change and become completely unrecognisable, then assuming we're still alive we could still do classical physics problems for fun. That's because it's an abstract structure, and must still make sense ...
A model of what, though? Why do people spend so much time studying it if it's just a system of equations? Why that one and not some other extremisation problem?etotheipi said:To me it is purely a model.
The point is that you have to mentally separate the the model, classical mechanics, from real world realisations. You can merely put things from the model into correspondence with things from the real world, and hope that they are in good enough agreement. And on that note, classical mechanics doesn't agree with experiment, if you look close enough - but that doesn't at all imply that it isn't a self-consistent and perfectly nice mathematical theory!Ibix said:You can't have experiments without theory, but without connecting specific concepts in a theory to quantitative real world measurements there's nothing to pick one system of equations out from the infinitely many other logically consistent systems of equations.
Classical mechanics (or physics in general) is not just the mathematical model, but also the description how it relates to real world observation. Otherwise it's not physics, just math.etotheipi said:The point is that you have to mentally separate the the model, classical mechanics, from real world realisations.
You seem to confuse "theory" with "mathematical model". A physical theory also includes the description of the relationship between the mathematical model and the observation.etotheipi said:In the context of this thread, it is completely unsatisfactory to appeal to a real, physical device - an accelerometer - in the theory.
In General Relativity, there are no global inertial frames. What there is, instead, are "local inertial frames". At any point in spacetime, you can create a coordinate system that is approximately inertial in a small enough region around that point.feynman1 said:If This acceleration is most naturally quantified with respect to inertial frames, then are inertial frames absolute and are they always inertial?
Didn't read the entire thread, but there are non-inertial frames that do not involve acceleration.feynman1 said:If a frame is a non inertial frame, then it must have an acceleration.
I disagree. Let's look at Newton's laws of motion. The first two just say that the acceleration of an object is proportional to the force acting on that object. That is true whether or not you consider "inertial forces" to be real forces, or not.etotheipi said:The point I'm making is that I haven't really noticed any classical mechanics textbooks use 'proper acceleration', and there isn't particularly a need to introduce it.
It might be true that classical physics doesn't make a big deal about proper acceleration. But that's because making the distinction between proper acceleration and coordinate acceleration is equivalent to first formulating the laws of motion in an inertial coordinate system, and then transforming to see what they are in a noninertial coordinate system.stevendaryl said:I disagree. Let's look at Newton's laws of motion. The first two just say that the acceleration of an object is proportional to the force acting on that object. That is true whether or not you consider "inertial forces" to be real forces, or not.
But then look at the third law, which can be stated informally as this: "If an object has a force ##\vec{F}## acting on it, then it must also exert a force on the rest of the universe that is equal to ##-\vec{F}##".
The third law is the basis for the conservation of momentum. Strictly speaking, Newton's formulation only applied to forces between objects and didn't consider the possibility of forces due to fields, but in later formulations of classical mechanics, this was extended to fields. The fields themselves carry momentum, and the third law applies to the interaction between fields and particles.
The third law only applies to proper forces (proportional to proper acceleration). In a rotating coordinate system, the "forces" such as the centrifugal force and Coriolis force don't obey the third law. Centrifugal force seems to pull an object away from the center of rotation, but there is no corresponding "equal and opposite" force exerted by that object.
...and "appropriately small" means that the gravitational field in the region under consideration is sufficiently homogeneous, i.e., tidal forces are negligible.stevendaryl said:In General Relativity, there are no global inertial frames. What there is, instead, are "local inertial frames". At any point in spacetime, you can create a coordinate system that is approximately inertial in a small enough region around that point.
The criterion for a system ##(x,y,z,t)## to be inertial is, roughly speaking, that a point mass that is not affected by any non-gravitational forces will travel along straight lines: ##\frac{dx}{dt} = \text{constant}##, ##\frac{dy}{dt} = \text{constant}##, ##\frac{dz}{dt} = \text{contant}##. You can't make this absolutely true in the real universe, because of spacetime curvature. But what you can do is make it approximately true, which means that for any desired level of accuracy in the measurement of velocities, you can choose an appropriately small region of spacetime and an appropriate coordinate system such that ##\frac{dx}{dt}, \frac{dy}{dt}, \frac{dz}{dt}## for test particles don't change within that region, to that level of accuracy. Or something like that.
