Whether a non-inertial frame is absolute
94 replies · 8K views
etotheipi said:
This is personal preference :smile:
To me it is purely a model.
On this forum we use the professional scientific literature as the standard. It could be that there are professional sources that use the term “classical mechanics” in that way, but I have not seen them. Most sources describe classical mechanics as a scientific theory describing real-world macroscopic objects.
“The mathematical study of the motion of everyday objects and the forces that affect them is called classical mechanics.” https://www.livescience.com/47814-classical-mechanics.html
“Classical mechanics is used for describing the motion of macroscopic objects, from projectiles to parts of machinery, as well as astronomical objects, such as spacecraft , planets, stars, and galaxies. It produces very accurate results within these domains, and is one of the oldest and largest subjects in science, engineering and technology.” https://www.newworldencyclopedia.org/entry/Classical_mechanics
“Classical mechanics is the study of the motion of bodies (including the special case in which bodies remain at rest) in accordance with the general principles first enunciated by Sir Isaac Newton” http://farside.ph.utexas.edu/teaching/301/lectures/node3.html
“Classical mechanics is a physical theory describing the motion of macroscopic objects, from projectiles to parts of machinery, and astronomical objects, such as spacecraft , planets, stars, and galaxies” https://en.m.wikipedia.org/wiki/Classical_mechanics
And similarly for textbooks I have read. I have yet to see any standard source that claims that classical mechanics is to be identified with the mathematical model regardless of the presence or absence of any connection to experiment.
Have you seen such sources?
stevendaryl said:
The third law only applies to proper forces (proportional to proper acceleration)
This is the General Relativity view. In standard Classical Mechanics, Newtonian Gravitation is a force that obeys the third Law, even tough it doesn't cause proper acceleration. Although Classical Mechanics could be formulated differently (as already mentioned here) this is the standard formulation.
I wasn't actually talking about gravity. I was talking about other inertial forces such as the centrifugal force. There is no "equal and opposite" force to centrifugal force.
From the point of view of Newtonian physics, gravity is a real force, and acceleration due to gravity is proper acceleration.
That is not how I see the term "proper acceleration" usually used. This would be "classical proper acceleration", which does not always correspond to the reading of an accelerometer.
Good point. So we have two different notions of inertial coordinate system, and in Newtonian physics, they disagree in the presence of gravity:
  1. Proper acceleration means what an accelerometer shows. An inertial coordinate system is one in which objects at "rest" have zero proper acceleration.
  2. Proper acceleration is the acceleration as measured in an inertial coordinate system. An inertial coordinate system is one in which there are no "fictitious forces".
The second definition leaves a circularity that maybe can be resolved by applying Newton's third law. A "real" force is one for which there is a corresponding equal and opposite force?
I wonder, whether the notion of "proper acceleration" or "proper xyz" makes much sense within Newtonian physics. There we have simply "absolute time" and "absolute space" which are postulated to exist and providing an inertial reference frame. Time is a directed 1D oriented manifold and space a Euclidean affine space. This is the modern, abstract formulation for Newton's Lex Prima.
Of course, there's no way to really determine operationally Newton's absolute time and space, even within Newtonian mechanics, because of Galileo symmetry, i.e., any other reference frame moving with constant velocity against this fictitious absolute inertial frame has the very same properties as this absolute frame itself, but this doesn't matter for Newtonian mechanics at all.
Further the physical laws are all formulated wrt. the class of inertial reference frames (Lex II and III).
Acceleration is independent of the particular choice of an inertial reference frame, because it's a Galileo-invariant vector.
Gravitation in Newtonian physics is simply an interaction acting instantaneously at a distance, i.e., two bodies attract each other according to Newton's universal law of gravity,
$$\vec{F}_{12}=-\frac{G m_1 m_2}{|\vec{r}_1-\vec{r}_2|^3} (\vec{r}_1-\vec{r}_2)=-\vec{F}_{21}.$$
As any dynamical theory you can formulate also Newtonian mechanics in a generally covariant way, i.e., expressing the fundamental laws, as given in the class of inertial frames, in arbitrary coordinates, defined using a reference body that moves with arbitrary acceleration against the inertial frames. All you have to do is to introduce a "covariant time derivative" for vector components wrt. this non-inertial frame, if it is rotating against the inertial frames of reference (implying also how to take covariant time derivatives for any tensor components, but these you almost never need in Newtonian mechanics, except the tensor of inertia of a rigid body). Neither absolute time nor space as an affine Euclidean manifold for any non-inertial observer changes.
The funny thing is that accelerometers like the one in our smartphones indeed measure "proper accelaration" by construction. It shows ##\vec{a}=0## when in free fall in the gravitational field of the Earth which can indeed by taken as homogeneous in the usual cases of application. In a reference frame at rest wrt. the Earth it shows ##\vec{a}=\vec{g}## with ##\vec{g} \approx 9.81 \;\text{m}/\text{s}^2##.
Also this is very natural within Newtonian mechanics, because indeed a reference frame freely falling in a gravitational field of the Earth (as far as one can neglect tidal forces, i.e., can consider the gravitational field as homogeneous), is indeed an inertial frame of reference (due to the equivalence principle, which in Newtonian mechanics reduces to an empirical not further explainable fact that inertial an gravitational mass are equal).
"Yet within its known slow-motion domain, Newton’s theory will undoubtedly continue to be used for reasons of conceptual and technical convenience. And as a logical construct it will remain as perfect and inviolate as Euclid’s geometry." Rindler, Relativity, 2e, 2006, p109
This is actually the main reason that I hesitate to say things like “gravity isn’t a force in GR”. At least not without adding “locally”.
I don’t think that this is indeed claiming that classical mechanics refers to the logical construct alone, but I can see how someone with that opinion could read it thus.
A model, by itself, is math, not physics. It's only physics if it makes predictions that can be compared with reality. If it's just a model with no possible connection to reality, nobody would call it "physics".
Apologies for a late reply; the pubs were open again today 😄
Given any frame ##F = P \zeta \eta \xi## one can define the time derivative with respect to ##F## of an arbitrary vector ##\mathbf{u}##$$\mathcal{D}_F \mathbf{u} := \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \big{|}_{F} = \frac{\mathrm{d}{u}^{\zeta}}{\mathrm{d}t} \mathbf{e}_{\zeta} + \frac{\mathrm{d}{u}^{\eta}}{\mathrm{d}t} \mathbf{e}_{\eta} + \frac{\mathrm{d}{u}^{\xi}}{\mathrm{d}t} \mathbf{e}_{\xi}$$It's easy to show, given another frame ##G = Q \rho \sigma \tau##, that ##\mathcal{D}_F \mathbf{u} = \mathcal{D}_G \mathbf{u} + \boldsymbol{\omega} \times \mathbf{u}## where ##\omega_i = \frac{1}{2} \epsilon_{ijk} \dot{\mathcal{R}}_{jl} \mathcal{R}_{kl}## and ##(\mathcal{R}_{ij})## is the orthogonal, time-dependent matrix such that ##\mathbf{e}^G_i = \mathcal{R}_{ij} \mathbf{e}^F_j##.
Now let us show how to obtain the equations of motion for a particle in an arbitrary reference system. Begin with an inertial reference system ##K = Oxyz##, in which the Lagrangian is simply$$\mathscr{L} = \frac{1}{2} m v^2 - \varphi$$where ##\mathbf{v} := \mathcal{D}_K \boldsymbol{x}##. Let's now consider a second reference system ##L = O'x'y'z'## and define ##\mathbf{R}(t) := \overrightarrow{O(t)O'(t)}##, such that ##\boldsymbol{x} = \mathbf{R} + \boldsymbol{x}'##. Operating with ##\mathcal{D}_K## yields, upon defining ## \boldsymbol{\mathcal{V}} := \mathcal{D}_K \mathbf{R}## and ##\mathbf{v}' := \mathcal{D}_L \boldsymbol{x}'##\begin{align*}
\mathcal{D}_K \boldsymbol{x} &= \mathcal{D}_K \mathbf{R} + \mathcal{D}_K \boldsymbol{x}' \\
\mathbf{v} &= \boldsymbol{\mathcal{V}} + \left[ \mathcal{D}_L \boldsymbol{x}' + \boldsymbol{\omega} \times \boldsymbol{x}' \right] \\
\mathbf{v} &= \boldsymbol{\mathcal{V}} + \mathbf{v}' + \boldsymbol{\omega} \times \boldsymbol{x}'
\end{align*}It follows that\begin{align*}v^2 = \mathcal{V}^2 + v'^2 + (\boldsymbol{\omega} \times \boldsymbol{x}')^2 + 2 \mathbf{v}' \cdot \boldsymbol{\omega} \times \boldsymbol{x}' + 2 \boldsymbol{\mathcal{V}} \cdot \mathbf{v}' + 2 \boldsymbol{\mathcal{V}} \cdot \boldsymbol{\omega} \times \boldsymbol{x}'
\end{align*}The new Lagrangian is then written\begin{align*}
\mathscr{L}' = \frac{1}{2} m \left( \mathcal{V}^2 + v'^2 + \boldsymbol{\omega} \cdot (\boldsymbol{x}' \times (\boldsymbol{\omega} \times \boldsymbol{x}')) + 2 \mathbf{v}' \cdot \boldsymbol{\omega} \times \boldsymbol{x}' + 2 \boldsymbol{\mathcal{V}} \cdot \mathbf{v}' + 2 \boldsymbol{\mathcal{V}} \cdot \boldsymbol{\omega} \times \boldsymbol{x}' \right) - \varphi
\end{align*}where we have re-written ##(\boldsymbol{\omega} \times \boldsymbol{x}')^2 = \boldsymbol{\omega} \cdot (\boldsymbol{x}' \times (\boldsymbol{\omega} \times \boldsymbol{x}'))##. Let us now compute the derivatives of the Lagrangian\begin{align*}
\frac{\partial \mathscr{L}'}{\partial x'^i} &= -m \epsilon_{ijk} \epsilon_{klm} \omega^j \omega^l x'^m -m \epsilon_{ijk}\omega^j (\mathcal{V}^k + \dot{x}'^k) - \partial_i \varphi \\ \\
\frac{\mathrm{d}}{\mathrm{d}t} \frac{\partial \mathscr{L}'}{\partial \dot{x}'^i} &= m \dot{\mathcal{V}}^i + m \ddot{x}'^i + m\epsilon_{ijk} ( \dot{\omega}^j x'^k + \omega^j \dot{x}'^k)
\end{align*}The Euler-Lagrange equation ##\partial \mathscr{L}' / \partial \boldsymbol{x}' = d_t \left(\partial \mathscr{L}' / \partial \dot{\boldsymbol{x}}' \right)## thus implies the following equation of motion in the ##L## reference system, after converting from suffix notation back into vector notation,$$m \mathbf{a}' = - \nabla \varphi - m \boldsymbol{\mathcal{A}} - 2m \boldsymbol{\omega} \times \mathbf{v}' - m \boldsymbol{\alpha} \times \boldsymbol{x}' -m \boldsymbol{\omega} \times (\boldsymbol{\omega} \times \boldsymbol{x}')$$where ##\boldsymbol{\mathcal{A}} := \mathcal{D}_K \boldsymbol{\mathcal{V}} = \mathcal{D}_L \boldsymbol{\mathcal{V}} + \boldsymbol{\omega} \times \boldsymbol{\mathcal{V}} ## is the translational acceleration of the ##L##-system with respect to the ##K##-system and ##\boldsymbol{\alpha} := \mathcal{D}_{K} \boldsymbol{\omega}## is the rotational acceleration of the ##L##-system with respect to the ##K##-system. And of course ##\mathbf{a}' = \mathcal{D}_L^2 \boldsymbol{x}'## is the acceleration of the particle with respect to the ##L##-system.
This is the equation of motion of a particle in an arbitrary reference system ##L##; the additional terms arising from the co-ordinate transformation are not forces, although they are sometimes affectionally referred to as 'inertial forces'.
Good to see you have your priorities in order. :wink:
  • Haha
@etotheipi Of all the people I know that are fans of pubs you seem to have the best mathematical skills I must say.
I would like to have a drink with you in a nice inertial frame but only if you promise me you wouldn't introduce any centrifugal forces. Otherwise it might end badly for my stomach.
  • Haha
"The Inertial Frame" would be an excellent name for a pub. People would naturally remain at rest inside.
  • Haha
But in GR, one doesn't even need to neglect tidal forces. For geodesic motion, the proper acceleration is zero even if tidal forces are not zero. So maybe in that sense, the more natural language might be Newton-Cartan, as @Dale was perhaps suggesting, though I don't know that theory well enough to know if the proper acceleration carries over from GR.
Can such a thing as an infinitesimal accelerometer exist (so that it measures proper acceleration even when tidal forces are not zero)? If it cannot, then what an accelerometer measures is not the proper acceleration.
In the standard Newtonian formulation. I agree the proper acceleration is not so natural a concept, so I would prefer to use the term specific force for what an accelerometer measures. Wikipedia does use "proper acceleration" as a synonym for "specific force". But is the specific force (defined in standard Newtonian language) the same as the proper acceleration in Newton-Cartan (defined by inheritance from GR)?
If a real gravitational field is present also within GR you do not have a global inertial frame of reference. A free-falling reference frame is inertial strictly speaking only in one point, where all the Christoffel symbols are made to vanish. Because at presence of a gravitational field the curvature tensor is not 0, and this is true independently of the choice of the reference frame or coordinates, i.e., you always have tidal forces in a free-falling reference frame. It depends on the accuracy you aim to measure them how large the region in spacetime is you choose to neglect them.
As far as I can tell, yes.
Proper acceleration, being the reading on an accelerometer, is not a theory-based concept. It is an operational definition. You can use it in any theory.
This is a practical issue, but not an in-principle problem. The usual alternative approach for identifying an inertial frame relies on isolated particles. That also is rife with practical problems, but is not in-principle problematic.
But is this true even when we consider that the accelerometer must be calibrated? Wouldn't one need Newtonian mechanics and inertial frames (or GR and proper acceleration) to calibrate an accelerometer?
It is not true that accelerometers must be calibrated. You can build accelerometers that don’t require calibration, but their manufacturing is more demanding and expensive. Such expensive non-calibrated accelerometers are mostly used for gravimetry.
Building a device that requires calibration is mostly an economic decision. By requiring calibration you can shift some of the device’s cost from the manufacturer to the user. So for a similar precision a calibrated device can be less expensive to purchase than an un calibrated device. That applies for accelerometers as well as other devices.
The thing with accelerometers is that a stable and accurate reference standard is free and readily available. So most accelerometers are designed requiring calibration because customers are willing to accept the burden of calibration for an accelerometer whereas they may not for other devices with less available standards.
But you can't treat a frame in which all of the geodesics in question have constant spatial coordinates as an inertial frame if tidal forces are not zero, because in an inertial frame, geodesics that start out at rest relative to each other must remain at rest relative to each other. That will not be the case if tidal forces are not zero.
I'm not sure what you're trying to say here. In terms of the math of GR, an accelerometer measures the path curvature of a single worldline. It does not measure any relationship between multiple worldlines. So in terms of the math of GR, all accelerometers are infinitesimal. (Note that a geodesic worldline has zero path curvature, so if tidal gravity is present, accelerometers following multiple geodesic worldlines will all read zero even as those worldlines converge or diverge due to tidal gravity.)
In practice, of course, any actual accelerometer must have a finite size ##L##; so any actual accelerometer has two practical limitations: (1) it can only measure accelerations that are much smaller than ##1 / L##; and (2) it will not work at all unless whatever spacetime curvature (tidal gravity) is present has magnitude much less than ##1 / L^2##. (I am here using units in which ##G = c = 1##, which is common in GR.)
These practical limitations are easily met here on Earth, or even in all the other places we have so far sent accelerometers. A typical accelerometer we use might have, say, ##L = 0.1 \ \text{m}##. This means ##1 / L## is about ##10^{17} \ \text{g}## (it's ##c^2 / L## in conventional units), and ##1 / L^2## is the spacetime curvature corresponding to an energy density of about ##10^{44} \ \text{kg m}^{-3}##, or ##10^{41}## times the density of water (the energy density ##\rho## in conventional units is given by ##c^4 / 8 \pi G L^2##). So the accelerometers we use in practice present no problem at all as far as treating them as infinitesimal for the accelerations and tidal gravity conditions in which we use them.
I left out a third limitation, which is actually the most restrictive one for us here on Earth (and anywhere else we have so far sent accelerometers): the size ##L## of the accelerometer must be much smaller than the distance over which the local "acceleration due to gravity" varies by an amount large enough that the accelerometer is supposed to be able to detect the difference. This is not quite the same as the second limitation, because here we're not concerned with spacetime curvature being large enough to disrupt the internal structure of the accelerometer (which is what the second limitation is about); here we're concerned with the accelerometer being large enough that there won't be a single value of spacetime curvature everywhere inside it, to whatever degree of accuracy it can measure.
So, for example, spacetime curvature in Earth's vicinity is given roughly by ##G M / R^3## (I'll switch to conventional units here--there is variation with direction but we'll ignore it for this calculation since we're just looking at rough orders of magnitude), where ##M## is the Earth's mass and ##R## is the distance from the Earth's center. The equivalent "acceleration" this produces across an accelerometer of size ##L## is ##G M L / R^3##; the smallest acceleration the accelerometer can distinguish will have to be significantly larger than this. If we plug in ##L = 0.1 \ \text{m}## and assume we're on the Earth's surface, we get about ##10^{-7} \ \text{m s}^{-2}##, or about ##10^{-8} \ \text{g}##; so an accelerometer of that size here on Earth will only be able to distinguish accelerations that differ by significantly more than that.
I need to understand better: this seems totally disingenuous to me. Operationally how do you construct this instrument without theoretical reference? Starting from a world without accelerometers, what does this process look like? Unless they are identical how do we know they measure the same thing?
With blueprints or schematics. I am not being disingenuous, but it really is that simple. We can construct reference accelerometers from known designs, or we can just purchase them commercially with known accuracy and precision. They are standard pieces of lab equipment, just like clocks.
We are not starting from a world without accelerometers. They do exist and regardless of your theory they produce some set of numbers. The numbers that they produce are in fact independent of the theory used to analyze the device. If your theory predicts different numbers then the theory is falsified (or the device is broken).
This is not unique to accelerometers, but applies to any measurement device. Scales, clocks, rulers, voltmeters, ammeters, thermometers, etc. all produce measurements that are theory independent in the same sense as I intended above.
Dale said:
[accelerometers] do exist and regardless of your theory they produce some set of numbers. The numbers that they produce are in fact independent of the theory used to analyze the device
Thus the real-world accelerometers cannot be part of any particular theory itself! It seems really unnatural to reference a real-world, manufactured device when formulating the foundations of classical mechanics.
It'd be okay, I think, to define an ideal accelerometer as a theoretical notion (similar in spirit to how one defines an ideal clock) which simply measures the curvature at a point of a world line on a manifold equipped with a connection. And a real, physical accelerometer would more or less approximate the ideal accelerometer.
But trying to incorporate actual real-world stuff into the theory itself will never work, IMO! One must have a fully internally consistent theory which an alien in a parallel universe with different physical laws could, hypothetically, make perfect sense of.
It depends on what you want the word "theory" to mean. Do you want it to mean just a mathematical structure, which might or might not describe anything in the actual world, but which is consistent within itself? Or do you want it to mean such a structure plus the predictions it makes and the operational rules that tell you how to compare its predictions with actual data?
You are using the word in the first sense. @Dale is using it in the second. I personally would prefer the second usage myself, since to me, calling something a "theory" when we're talking about physics, or any observational science, only makes sense if we include the predictions and the comparison with data. I could concoct all sorts of wacky but internally consistent mathematical structures and call them "theories", but I suspect you would object to such usage on the grounds that those wacky mathematical structures obviously have nothing to do with physics. The reason you're concentrating on what you call "classical mechanics" is that it does have something to do with physics: it does make predictions and there are operational rules for comparing those predictions with data, and because of that we now know that this theory is not exactly correct; it's only an approximation that works in weak gravitational fields for relative motion at speeds much less than the speed of light. But if that's why you care about "classical mechanics" as a mathematical structure, then you can't have it both ways: you can't both care about it because it does make physical predictions and does give operational rules for comparing its predictions with data, but then insist that those predictions and operational rules aren't part of the "theory". Maybe they aren't part of the mathematical structure you're looking at, but they are part of why you care about it and why the term "theory" is justified when talking about it.
Why not? Why shouldn’t a theory reference things outside of the theory?
Why? Don’t you want the theory to predict their behavior?
I don’t share your opinion here. I think that operational definitions are an intrinsic part of the theory. That is the part that forms the so-called minimal interpretation. Why shouldn’t such essential concepts be part of the foundations of the theory?
I really do mean that it should solely refer to an internally-consistent mathematical structure. The theory-to-reality mapping is something you need to build on top of that. A translator. 😄
It's really important not to conflate the real world with abstract structures that live solely in one's mind 😉
Then, while I understand your preference, I do not think it is a very common preference among physicists. Nor do I think you can validly claim that the other preference, the one @Dale and I favor, doesn't make sense.
It's also really important not to ignore the fact that the reason we care about particular abstract structures is the predictions they make about the actual world. If the abstract structure you call "classical mechanics" didn't make such predictions, and didn't have many people believing for about two centuries that those predictions were exact, it would not be called "classical mechanics".
So let a scientific theory ##(F,I)## consist of an abstract mathematical framework ##F## and a minimal interpretation ##I:P\rightarrow R## mapping predictions ##P\subset F## to real world experimental results ##R##. Now we are in no danger of conflating ##F## with ##R##, and yet we can see that ##F## by itself is insufficient to form a theory.
  • Haha
