Which calculation should i use?@_@
  • Thread starter Thread starter shakie_ija
    Calculation
To determine the forces acting on a 1.4 kg bottle of milk lying horizontally, the discussion emphasizes the need to analyze the forces exerted by the two surfaces it rests on, particularly considering the angle of the right surface at 45 degrees. Participants suggest using fundamental equations such as F=ma and w=mg, while also considering the resultant force through trigonometric functions like cosine and sine. The importance of identifying all acting forces and calculating the net force, especially the vertical components, is highlighted. Confusion arises from varying attempts at solutions, indicating a need for clarity in the calculations. Accurate resolution of this problem requires a systematic approach to force analysis.
shakie_ija
which calculation should i use??@_@
a 1.4 kg bottle of milk is lying horizontally in the rack. the two surfaces on which the bottle rest r 900 apart, and the right surface makes an angle of 450 with the respect to the ground. each surface exerts a force on the bottle that is perpedicular to the surface. determine the magnitude of each of these forces
* the bottle is lying 90 degree vertically
f=ma?
w=mg?
or should i find the resultant force by using cos and sine
ive tried..but all the answer are different..
Call the force exerted by each surface on the bottle F. What other forces act on the bottle? What's the net force on the bottle? Consider vertical components.
