Which is more linear, a frictionless or slightly frictional pendulum clock?
A pendulum clock exhibits moderate nonlinearity at small angles of displacement, and introducing friction does not alter the nonlinear behavior of the restoring force. The term "simple harmonic oscillator" applies strictly to systems with a linear restoring force, typically used in small angle approximations for pendulums. A user shared their experience of constructing a 2-D pendulum that visually records its displacement over time, raising questions about the accuracy of using the linear period equation T=2π(L/g)^(1/2) in the presence of friction. The discussion emphasizes the distinction between linear and nonlinear dynamics in pendulum motion. Understanding these concepts is crucial for accurately analyzing pendulum behavior in practical applications.
Loren Booda
A pendulum (clock) is moderately nonlinear for small angles of displacement. Is simple harmonic motion better approached by introducing a degree of friction into its works?
Science news on Phys.org
I'm not sure what you mean by "moderately nonlinear" but, no, you won't change the way that the nonlinear "restoring force" behaves by adding damping. Perhaps you're confusing "nonlinear" with "unstable?"
Incidentally, the expression "simple harmonic oscillator" refers ONLY to a system with a linear restoring force and is often used in the small angle approximation to a pendulum.
Tide,
I helped a young man construct a 2-D pendulum whose bob traces out in sand its displacement vs time. It swings discernably for about ten cycles (a total of ~17 seconds), leaving both a record of its displacement and the number of periods. Is it a safe, albeit rough, approximation to use the linear period equation T=2pi(L/g)1/2 when such friction is involved?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
