Which speed is greater? Different question, Is this possible?
  • Thread starter Thread starter bored2death97
    Speed
The discussion revolves around two physics questions from a midterm exam. The first question concerns the speeds of three balls at a certain height, with participants debating whether their speeds depend on mass, if one ball has the smallest velocity, or if all have the same speed. It is clarified that while the vertical components of speed are the same due to gravity, the horizontal components differ, leading to varying total speeds. The second question involves two equal-mass carts on a frictionless track, where the consensus is that Cart A cannot move in reverse after colliding with Cart B, as momentum transfer does not allow for such an outcome. Overall, the conversation emphasizes the importance of understanding velocity components and conservation of momentum in physics problems.
bored2death97
This isn't a homework question, just did a midterm and I am curious about a question. it had this diagram. Same initial speed.
http://imgur.com/nsaDG
and it asked which statement is most correct about the speed at height, h (the line going across the graph)
a) It depends on their masses
b) Ball 3 has smallest velocity
c)All have same speed
There were a couple other options, but I forget them, and these were the ones I was contemplating. I put that ball 3 has a lower speed because when it is at the height indicated the speed goes to zero.I also have another.
Two carts sit on horiz. frictionless track. Equal masses. Cart A is moving towards cart B. Cart B is at rest. Is it ever possible for Cart A to move in reverse after the collision.
a) depends on conditions of collision
b) No, never
c) Yes
I put no, although I was thinking about that it depends on the conditions. I was thinking about if it was glues to the track, then it would go in reverse. But from what I know, the 2 cars either join together, one transfers all of its momentum to the 2nd, or they go off at different angles (since this is a horizontal track that wouldn't be possible).
The rules of this board require you to demonstrate your own attempt or considerations for solving any homework/test problem. Yes, that includes the past ones. Don't worry if you can't formalize it too well. Do the best you can.
There are many reasons for that. One is that it honestly helps us explain the problem to you when we see what it is that you are having problems with.
Fixed it, thanks for letting me know.
Right about the second, wrong about the first. The speed at that given height isn't zero for the 3rd ball because it is still moving towards the right. Because the acceleration due to gravity is the same for all three balls, the vertical speed of all three will be the same, but the horizontal speed will be different. You could calculate the total speed using Pythagoras's theorem, but just realize that if the vertical speed is the same, then the ball with the highest horizontal speed will have the highest total speed, and vice versa.
So because the ball on the right has the highest velocity to the right, it will have the greatest total velocity, even if it's vertical speed is zero.
b) No, never
c) Yes
The speed of ball 3 is not zero at h.
And I think that "frictionless" means no gluing of the cart to the track is allowed :)
You are over-thinking and making a logical mess that leads you to a wrongful conclusion.
What does conservation of energy has to say about all that?
It doesn't have to transfer all of its momentum. It can transfer just a fraction. Or it can even transfer more momentum than it has!
Picture it this way. Instead of cart B, a railroad cart on an actual railroad. Instead of cart A, you'll throw a ball at it. What's the outcome going to be?
To work it out more systematically, you can use the fact that center of mass will continue to move at the same velocity before and after collision. Try using three test cases mA = mB, mA = 2*mB, and mA = (1/2) * mB
If they all start with the same initial speed then they all start with different vertical components of velocity.
Ah crap, nevermind, I have to think more before I post.
What's your point? And who were you replying to?
Vorde said:
Because the acceleration due to gravity is the same for all three balls, the vertical speed of all three will be the same.
Sorry, I was replying to this.
Ignore that, when I was doing the math for myself I was doing something different from the original question, K^2 is right.
Someone please correct me if i am wrong, i just started my first physics class this year.
so for questions 1
All 3 balls have different horizontal components but horizontal components and vertical components are independent of each other therefore we can neglect it.
the way i look at it is. assuming initial velocity(vertically) is equal among all 3 balls, they will all have the same vertical component, acceleration due to gravity,and time. thus, when all 3 balls reach the same height, they have equal speed(vertically not horizontally) which would be zero seeing that the 3rd ball is a projectile reaching its maximum height.
again if someone can tell me if I'm on the right track that would be great. I feel i learn better when i try to explain things to someone else
You are correct but you initially said they begin with the same speed. That isn't the same thing. Speed is the magnitude of velocity regardless of the direction.
If they begin with the same speed then ball 1 has a greater vertical velocity because it has zero horizontal velocity. So it will go higher than h.
Maybe you could look up the question again and list all the options.
EDIT: Sorry I just realized you won't be able to do that.
Have you figured it out yet?
The problem statement defines mA = mB. It cannot transfer more than its own momentum in this setup.
This assumption is wrong.
Energy conservation is the best way to solve problem 1, as K^2 already posted.
Yeah. Missed that bit. OP's right about that one, then.
I haven't started conservation of energy yet so I am a bit confused abot that part.
also why is this assumption wrong?
The speed (the magnitude of the velocity vector) is the same for all 3 balls, but the direction is different. You can write the vertical component as ##v \sin(\alpha)## where ##\alpha## is the angle between initial direction and the floor. As this is variable, the vertical component of the velocity is different, too.
I asked my prof about the cart question, and he said the answer was no, which is what I put.
Didn't ask him about the other question, but a lot of people here are saying that it would have the same speed.
