Mentor
- 38,145
- 10,746
Yes, abaci is the correct plural, which I believe is pronounced ab' a see.dkotschessaa said:Yeah, this is kind of what I was thinking. I believe that mechanical devices like slide rules and abucuses (abaci? I don't know the plural) can really help mathematical intuition.
Working with a slide rule can help with mathematical intuition because you have to figure out the correct power of ten for many calculations, such as 432 x 363. The way it works is that you put the 1 marker on the C scale on, say, 4.32 on the D scale, and then slide the cursor to 3.63 on the C scale.(In doing this I actually had to put the 1 marker at the right end of the C scale on 4.32). On the D scale, the cursor shows a little shy of 1.57. Since 432 is really 4.32 X 102 and 363 is really 3.63 X 102, my slide rule answer is 15.7 X 104, or 1.57 X 105. This isn't too far from the exact answer, 156,816.
How a slide rule works for multiplication can give one a good insight to logarithms, as many of the scales are laid out logarithmically. The 1 on the left end of the C and D scales represents 0 (the log10 1 is 0). The 1 on the right end of these scales represents 10 (whose log is 1). The 2 on these scales is placed about .3010 of the way between the two ends, and 3 is placed about .4771 of the way.
When you multiply 2 and 3, you are really adding the logs of these numbers, and getting the log (base 10) of the answer. For example, placing the left-end 1 of the C scale on the 3 of the D scale, and then moving the cursor to the 2 on the C scale lines up with the 6 marker on the D scale. In effect you are doing this addition: ##\log 3 + \log 2 = \log(3 \cdot 2) = \log 6##.
Division is just the opposite; instead of adding the lengths (adding the logs), you subtract the lengths.To calculate 3/2, put the 3 on the C scale above the 2 on the D scale, and read the answer on the D scale under the 1 on the C scale. You are effectively subtracting the length of 2 (on the C scale) from the length of 3 (on the D scale) to get the quotient, keeping in mind that what I'm referring to as "lengths" are really logarithms in base-10.
