Why an electron at rest cannot emit a photon?
An electron at rest cannot emit a photon due to the conservation of energy and momentum. When considering the emission of a photon, the total energy and momentum before and after must remain equal, which is impossible for a stationary electron. Even if the electron were moving, the same conservation principles apply, leading to the conclusion that emission cannot occur without violating these laws. Additionally, current theories suggest that an electron cannot decay into a photon and a neutrino, as this would violate charge conservation. Therefore, the fundamental laws of physics prevent a resting electron from emitting a photon.
Docdan6
Hi!
Could someone explain to me why an electron at rest without any influence from a magnetic or electric field cannot emit a photon ?
Could you explain it mathematically too ?
Thanks in advance...
:welcome:
Think about it. Momentum must be conserved. Energy must be conserved.
anorlunda said:
:welcome:
I know that ! But how can I prove it mathematically? (I don't have a background in physics I'm a pharmacologist...)
There is no solution where energy and momentum before emission equal energy and momentum after. Therefore, it can't happen.
You must be interested in physics, that is hardly a pharmacological question. :smile:
Likes Docdan6
Not even a moving electron, without influence of an electric or magnetic field, can emit a photon.
A photon at rest has energy just from its mass (mass-energy equivalence). If it would emit a photon, you would have energy from the electron mass, plus energy from the photon, plus kinetic energy from the electron (it has to move to keep the center of mass at the same place). That doesn't work.
For a moving electron, you can consider the process in the rest frame of the electron, with the same conclusion.
Likes Docdan6
Just in case this was a possible option, current belief is that an electron can't decay into a neutrino and a photon, because charge would be lost, which would violate the law of charge conservation (this assumes there isn't some smaller charged particle that no one has discovered yet).
Likes Docdan6
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
9K
