Why are hyperbolic functions defined in terms of exponentials?
Hyperbolic functions are defined in terms of exponentials, drawing parallels to trigonometric functions through complex arguments. Their origins may stem from geometric definitions related to the rectangular hyperbola, similar to how circular trigonometric functions are defined. The relationship between hyperbolic functions and exponentials can also be derived from power series of complex variables, highlighting their analytic properties. While the geometric approach seems more intuitive, the exponential definitions provide a robust framework for advanced mathematical applications. Ultimately, hyperbolic functions serve significant roles in various fields, extending beyond their geometric interpretations.
neginf
Where do the definitions of hyperbolic functions in terms of exponentials come from ?
Mathematics news on Phys.org
Maybe somebody tried e^i*x=cos x+i*sin x and e^-i*x=cos x-i*sin x with i*x instead of x and got functions that acted a lot like regular trig functions so they named them a lot like trig functions, like cos(i*x)=cosh x.
Could that be where those definitions come from ?
If so,do they come from somewhere else also ?
AFAIK, the hyperbolic trigonometric functions were originally defined geometrically, analogously to the ordinary (circular) trigonometric functions, just based on the rectangular hyperbola rather than the circle.
Thank you for that.
I wonder if the definitions in terms of exponentials can be gotten from the geometric definition. That would seem more natural than adding and subtracting trig functions with imaginary arguments.
neginf said:
Thank you for that.
The most "obvious" formula from the geometry of a hyperbola would be cosh^2 x = sinh^2 x + 1.
Another "obvious" starting point from a rectangular hyperbola is to define log(x) as the integral of 1/x, and exp(x) as the inverse of log(x).
From the point of view of "advanced" math, probably the simplest way to define the trig hyperbolic and exponential functions is using power series of complex variables. Then the relations between them are obvious (and they are all so-called analytic functions defined for all complex arguments, which means they have lots of nice properties), but you then have to prove they have something to do with angles, circles, and hyperbolas. But many of the their uses in "advanced" math and physics don't have much to do with angles and hyperbolas anyway...
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
