Why are noble gases, gases?
In summary, the density of an element is a bit of a funny thing to be talking about. It depends on how you measure it, and it doesn't have anything to do with how hard the atoms are trying to complete a shell.
gateman234
[SOLVED] why are noble gases, gases?
this has bothered me for some time,
what determines the density of an element at normal atmoshpheric conditions?
and more importantly what determines if a substance at s.t.p is a gas solid or liquid
gas laws, maybe?
i was thinking there might be some repulsion and atractions between atoms, like with Ar it contains a full outer shell which means to gain more electrons it would require a new level which would take a lot of energy, compared to Sulfur which is trying to complete a full outer shell, which reqiures less energy. so there is more atractration between atoms.
this only can aply for some atoms, help?
have you done anything on the different types of intermolecular force yet? If so, you will easily realize partly why the noble gases are, in fact, gases. The "density" of an element is a bit of a funny thing to be talking about, because in gas terms we generally don't talk about density in the same way (we don't say there is so many kg/m^3 of argon, we say there are so many ppm or ppb.
Looking at your posts so far it seems you have phrased everything only in terms of electron shells. Admittedly I find that just about all chemistry (apart from physical chemistry) can be explained by electron shells (hence why I'm more of a physicist), but maybe you should wait a little while and things will become clearer to you.
In argon, and indeed any element you have only weak van der waals forces between particles, so that's why most of the non-metals are in fact gases, until you get up to really heavy stuff.
Attraction and repulsion between atoms has absolutely nothing to do with how hard they are "trying to complete a shell". If you want to understand more, look up intermolecular forces and how they work. It should be very soon part of your chemistry course.
And finally, re your other post, this should definitely be in the chemistry subforum.
ok, thanks for your time.
1. Why are noble gases, gases?
Noble gases are gases because they have a full outer electron shell, making them stable and non-reactive. This stability gives them low boiling points, which allows them to exist in a gaseous state at room temperature.
2. What makes noble gases different from other gases?
Noble gases, also known as inert gases, have a complete outer electron shell, making them chemically stable and non-reactive. This sets them apart from other gases which have incomplete outer electron shells and are more likely to react with other elements.
3. How were noble gases discovered to be gases?
Noble gases were discovered to be gases through various experiments and observations. In 1785, Henry Cavendish first discovered the presence of a small amount of an unknown gas in the air, which was later found to be neon. In 1894, William Ramsay and Lord Rayleigh discovered argon while studying the density of nitrogen. Through further experiments, they also discovered helium, krypton, and xenon to be gases.
4. Why are noble gases called "noble"?
Noble gases are called "noble" because they were initially thought to be completely unreactive and unable to form compounds with other elements. This was later found to be untrue, as some noble gases can form compounds under certain conditions, but the name has stuck.
5. Can noble gases be used for anything?
Yes, noble gases have many practical applications. Helium is used in balloons and airships due to its low density, and in cooling systems due to its ability to conduct heat away from objects. Neon is used in neon lights and signs, and argon is used in light bulbs and welding. Krypton and xenon are used in various lighting applications and in medical imaging.
  • Other Physics Topics
12K
  • Atomic and Condensed Matter
