Why are the poles of a magnet stronger?
The poles of a magnet are stronger due to the nature of the magnetic field, which is not a force but a field affecting magnetic dipoles. The field lines around a magnet are denser at the poles, indicating a stronger field and a greater force on dipoles placed there. This concentration of field lines results in a significant variation in field strength, causing dipoles to experience a greater force at the poles compared to other areas. Additionally, all dipoles experience torque that aligns them with the field, but only a non-uniform field produces a linear force that displaces them. Understanding these principles clarifies why the poles of a magnet exhibit greater strength.
stmartin
Are the force around the poles compressed, so it makes the poles of the magnet stronger than the other parts? Thanks.
There is no "force" around a magnet. There is a field. The field affects things with magnetic charge -- in the case of magnetisms, magnetic dipoles. The field looks roughly like that pattern you get when you sprinkle iron filings about the magnet. The force exerted on a dipole due to a field is proportional to the strength of the dipole (obviously -- we actually define strength of dipoles this way) and the rate at which the field falls off. Note that all dipoles will experience a torque that tries to align them to the field (which is why the field is shown by iron filings -- they're miniature dipoles), but only a non-uniform field causes a linear force, displacing the dipoles. If you study the field lines about a bar magnet, you will notice that the field lines "come together" to end at the pole -- this signals the fact that the field is strongly varying there, because you go from very few lines crossing per area to many lines crossing per area. Thus a dipole placed there feels a much greater force.
Ok, thank you very much.
