Baluncore
- 10,321
For double precision floating point; 25.15 = 25.149999999999977;Zap said:I noticed that when reading the file, there are floating point errors in the results. For example, a cell that contains 25.15 will be 25.149999999999977 in the pandas data frame.
That is NOT an error. It is a failure to format and round the output.
If you look at the excel formatting information for numbers in the column that shows 25.15, you will probably see it is specified to display as "xxx.xx"; which will show the number rounded to 2 decimal places. Excel is storing the double precision number as 25.149999999999977 internally.
If you want to control the way a double precision number appears in pandas, you will need to read the pandas manual on display formatting, which probably uses the Round(,) format function. Like Excel, pandas is also storing the double precision number as 25.149999999999977 internally.
https://www.xspdf.com/resolution/51898492.html
