Why can't I use contour integration for this integral?
5 replies · 2K views · last reply
Insights Author
Consider the integral ##\displaystyle \int_{-\infty}^\infty \frac{e^{-|x|}}{1+x^2}dx ##. I should be able to use contour integration to solve it because it vanishes faster than ## \frac 1 x ## in the limit ## x \to \infty ## in the upper half plane. It has two poles at i and -i. If I use a semicircle in the upper half of the plane, I should only consider the residue at i which is:
## \displaystyle \lim_{z\to i} \frac{e^{-|z|}}{i+z}=\frac{e^{-|i|}}{2i}=\frac{1}{2ie} ##
So the integral is equal to ## \frac{2\pi i}{2ie}=\frac \pi e \approx 1.15 ##. But wolframalpha.com gives an expression involving Ci(x) and Si(x) that approximates to 1.24. What is wrong here?
Thanks
Looks to me Wolfram is doing some numerical integration. When I do a primitive numerical integration with excel I get about the same answers they do.
Your answer is correct
(How did you get this Ci and Si answer from wolfie ?)
I don't know off the bat how to derive the right answer, but contour integration by using residues only works for analytic functions, and the use of an absolute value, [itex]|x|[/itex], makes your integrand non-analytic.
That link is for the integrand [itex]\dfrac{e^{itz}}{1+z^2}[/itex], not [itex]\dfrac{e^{-|z|}}{1+z^2}[/itex]
Yeah, I missed that completely. o:) o:) o:) though to be smart and use ##t=i##
(For the numerics looked at ##[0,\infty>##)
Changed your avatar, didn't you ? Less colorful but more cultural !
