Why can't light go thru solids?
  • Thread starter Thread starter quantumh2o
    Light Solids
Light cannot pass through most solids due to interactions with the atomic lattice, where photons are absorbed and re-emitted, causing delays in their travel. In contrast, many liquids allow photons to pass because their molecular structure does not impede light in the same way. The energy from absorbed photons is transferred into lattice vibrations, known as phonons, while the photon is effectively "waiting" to be re-emitted. The discussion raises questions about the transparency of liquids to different parts of the light spectrum compared to solids. Overall, the complexities of optical conductivity and atomic interactions play a crucial role in light's behavior in various materials.
quantumh2o
With the huge distances between atoms, relative to the size of the atoms, why aren’t photon packets able to travel through most “solids”? Why are those same photon packets able to travel through many liquids?
Science news on Phys.org
I found your question interesting quantumh20.
Sorry I don't have an answer for you just another question because of your question.
Are transparent liquids non-transparent to a different part of the spectrum than solids?
You might want to start by reading one of the FAQ entry in this forum (General Physics) on photon transport in matter. It is a "start", since there are many other factors involved in optical conductivity in solids.
Zz.
"On the other hand, if a photon has an energy beyond the phonon spectrum, then while it can still cause a disturbance of the lattice ions, the solid cannot sustain this vibration, because the phonon mode isn't available. ... So the lattice does not absorb this photon and it is re-emitted but with a very slight delay. This, naively, is the origin of the apparent slowdown of the light speed in the material. The emitted photon may encounter other lattice ions as it makes its way through the material and this accumulate the delay."
Where does the photon go while it is waiting to be 're-emitted'?
The energy goes into vibrations of the solid (phonons) while it's "waiting".
Thanks.
Sounds similar to the action with electrons.
Is it? Does it mean, in a similar vein, that the photon disappears and a new photon is emitted with each interaction; as it does when an electron absorbs the photons energy and gains that energy? Or is that not right? I'm still not sure where your answer is on this even with your explanation I apologise.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
