Why can't we apply Gauss's law to a circular disk?
The discussion revolves around the application of Gauss's law to a circular disk of charge, comparing it to the application of the law to infinite planes or plates. Participants explore the implications of symmetry in these scenarios and the challenges of deriving electric fields analytically for finite geometries.
  • Some participants note that Gauss's law can be applied to any electrostatic situation, but it yields simple results primarily in cases with high symmetry, such as infinite planes.
  • Others argue that a circular disk lacks the symmetry necessary for straightforward application of Gauss's law, particularly when considering finite radii.
  • One participant mentions that when the radius of the disk approaches infinity, the situation resembles that of an infinite plane, allowing for the exploitation of symmetry.
  • Another participant emphasizes that solving for the electric field of a finite disk analytically is complex and typically requires methods beyond Gauss's law, such as solving the Poisson equation.
  • Some participants express confusion over the implications of treating a disk with infinite radius as an infinite plane, questioning whether this constitutes a valid test of Gauss's law.
  • Links to external resources are provided to illustrate examples involving infinite numbers of infinitely thin rings, which relate to the discussion of electric fields from charged disks.
Participants generally agree that Gauss's law applies to various electrostatic situations but disagree on its effectiveness for circular disks due to the lack of symmetry. The discussion remains unresolved regarding the best approach to analytically derive the electric field for a finite disk.
Limitations include the dependence on the definitions of symmetry and the challenges of applying Gauss's law to non-symmetric configurations. The discussion also highlights the complexity of transitioning from finite to infinite geometries.
r0ss
We apply Gauss's law to find electric field at a point due to chaged plane or plate. But what's wrong when applying to circular disk which can also be considered as a plane?
Hi Ross, :welcome:
In those example applications (infinite plate, sphere, ... ) there is a symmetry being exploited. For a disk (many disks are circular :wink: ) of charge there is no such symmetry.
Nothing is wrong with it. You can always apply Gauss’ law. However, it only gives you simple easy formulas when you can exploit a high degree of symmetry. Otherwise you would just use it numerically.
Try it. Are you able to solve it analytically?
Gauss's law applies to ANY electrostatic situation. However, it doesn't mean that it can be solve analytically or easily in all those situations. Only in high-symmetric cases can this be done. Otherwise, you will have to solve it numerically.
Zz.
Thank You. I studied and understood that the plane in the question was an infinite plane but in case of the disk it was defined by finite radii R. I tested the equation derived from such disk assuming R is infinity which gave me the same equation derived assuming infinite charged plate using Gauss's law. When we consider R is infinite, we can exploit symmetry.
In case of disk having finite radii right?
Yes. You can consider limiting cases: close by above the surface the disk looks like ifinite and very far away it looks like a point charge.
I don't understand what this means.
A disk with "infinite radius" is an infinite plane. The shape, whether it is a disk, a rectangular plate, an oval plane, etc... no longer matters. So when you said that you "tested the equation" by using R → ∞, aren't you just applying Gauss's law to the usual infinite plane of charge? You haven't "tested" anything.
What we do in graduate level E&M (i.e. when you start using texts such as Jackson's Classical Electrodynamics), is that you solve for things like this, i.e. a finite disk of charge, and then, you see if (i) the off-axis solution matches the on-axis solution, and (ii) at field points very far away, the series solution approaches that of a point charge solution.
But none of these can be easily solved using Gauss's law. In fact, the whole point of solving these types of problems is to get the students to solve the Poisson equation and using Green's function method.
Zz.
Zz.
There was two question. 1. find electric field due to infinite charged plate. In the solution, Gauss's Law was applied.
2. Find electric field due to charged disk having radii R at a point on the axis. In this case, a lengthy calculation had made to find the field. So I thought why can't we use Gauss's law. I tried to apply Gauss's law in the same manner in case of charged plane and failed to derive the equation in the solution for disk problem. Then I understood in case of finite value of R, we can't exploit symmetry hence Gauss's law. Finally I put value of R = infinity in the equation and found that it brcoming equation for infinite charged plane.
That was the whole scenario...
Amazing! Thank you BvU... ☺
rcgldr said:
Links that lead to an example using an infinite number of infinitely thin rings:
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html#c3
r0ss said:
Yes. I saw it and to skip those lengthy calculation, I was to try applying Gauss's Law. But we can't right?
If R is infinite, then the fraction part goes to zero, leaving just the 1 as a multiplier, simplifying the answer to $$E = k \ \sigma \ \ 2 \ \pi$$
For a infinite rectangular plane you need to treat it as an infinite number of infinitely long lines with zero width (the result ends up the same).
  • · Replies 29 ·
  • · Replies 20 ·
