Why do conservative forces try to reduce potential energy?
Conservative forces are defined as forces that act to minimize potential energy within a system, as they are the negative gradient of the potential field. This means that the force directs an object toward regions of lower potential energy, analogous to a ball rolling downhill. The discussion highlights the relationship between work and potential energy, noting that positive work results in a decrease in potential energy. The concept of a conservative force is further clarified through its physical interpretation, emphasizing that it naturally leads objects toward areas of maximum decrease in potential. Understanding this relationship enhances comprehension of how forces interact with potential fields in physics.
Soren4
I do not understand the reason why a conservative force always "tries" to reduce the potential energy of a system at its minimum (forgive me if I said it in a wrong way).
The explanation I gave me is: since for a conservative force, from the definition of potential energy, W=-\Delta U that means that if the work is positive, the potential energy decreases. Now, saying "the work is positive" means that the force is not opposing the displacement (more precisely \vec{F} \cdot \vec{ds}>0) or equivalently that the kinetic energy is increasing. Nevertheless I do not see why a (conservative) force should "naturally" do positive work (since this depends also on \vec{ds}>0). This is surely a wrong explanation.
So what is the correct reason for this? And how to interpret this fact?
What would happen if the direction of the force were reversed?
I don't like the work explanation either. If we throw a rock up in the air then gravity does negative work on the rock while it is moving up.
An explanation I like better is that a conservative force defines a potential field, and the force is the negative gradient of that field, which means that the force points in the direction of the greatest decrease of the field (like how a ball on a hill will roll down in the direction of the steepest gradient). So the force is always pushing a particle in the direction of maximum decrease of potential.
Likes PhanthomJay and Soren4
Thanks a lot for the answer! It is more clear now! If I may ask, how to interpret "physically" (less then mathematically) the fact that the force is the negative gradient of the potential field (and so it is directed towards the greatest decrease of it)? Of course it is a consequence of how the potential field has been defined but is there something more (from the point of view of physics) in this?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
