leila
- 18
- 0
Why do gases absorb neutrons less readily than water?
Any ideas on the above question?
Leila
Leila
Well that actually depends on the gas. He4 is a very stable nucleus, 2 protons and 2 neutrons in a very stable configuration. So it effectively does not absorb neutrons. On the other hands, He3 interacts non-elastically with neutrons (n,p) with a microscopic cross-section of about 5330 barns. In fact, in certain transient fuel experiments, coils of He3 are used just prior to the test to shield the test rod.leila said:Why do gases absorb neutrons less readily than water?
Astronuc said:Each atom has an energy-dependent microscopic cross-section (\sigma) associated with it. The microscopic cross-section is the interaction rate per atom in a target per unit intensity of the incident beam, and in a sense is a probability of interaction. It's unit is the barn and 1 barn = 10-24 cm2.
Multiplying the microscopic by the elements (isotopes) atomic density yields the macroscopic cross-section (\Sigma). The macroscopic cross-section is simply the probability of interaction per unit length of distance traveled by a particle, e.g. a neutron. See example calculation of macroscopic cross-section here - http://www.tpub.com/content/doe/h1019v1/css/h1019v1_117.htm
The density of gases is about 2 or 3 orders of magnitude less than water, which is usually pressurized.
CarlB said:It's not that simple. See fig 1. from the following paper, which shows that liquid H2 and gaseous H2 have very different cross sections, though the cross sections approach one another at high enough neutron energies:
http://ucn.web.psi.ch/papers/PhysRevLett_94_212502.pdf
Note that the above are total cross sections (most of which is scattering), and not absorption cross sections.
By the way, I read the OP's question as having to do with the phase difference for the target, and replaced "water" with "liquid", so the comparison is of one phase with another for the same target molecule. Otherwise the question doesn't make a lot of sense.
Carl
It is that straightforward, although the calculations are not necessarily trivial.Multiplying the microscopic by the elements (isotopes) atomic density yields the macroscopic cross-section (\Sigma). The macroscopic cross-section is simply the probability of interaction per unit length of distance traveled by a particle, e.g. a neutron.
