- 6,962
- 6,041
That is a very nice answer. It is not the only answer. Thank you for sharing.
Why? Write down the math and the criteria you used. What do you mean when you say an object rotates around a point? Did you just randomly pick A or was there some reason you used?John Mcrain said:
Because my eyes see this, same like I see that ocean is blue.Dale said:Why?
So to determine the point something rotates around we have to submit a picture to @John Mcrain and get your eyes on it. That is a terrible rule.John Mcrain said:Because my eyes see this, same like I see that ocean is blue.
Isnt that so obvious?
You should have a single rule. Not multiple rules.John Mcrain said:Because if you swimm inside or outside of white circle(boat path),boat will not hit you, but if you swimm at white circle, boat will hit you.
Because centripetal force that keep boat rotating around point A is equal to m x v2 / r , where r is distance from A to boat...
I'm disappointed it doesn't include "E" - about its center of mass!John Mcrain said:
John Mcrain said:About which point boat rotate? A,B,C,D or any point ?
My answer is A.
You are confusing "rotation" with "translation along a circular path".John Mcrain said:Because centripetal force that keep boat rotating around point A ...
Camera show reference frame of water, so I answer for this frame.A.T. said:If you:
- choose to describe the motion in the rest frame of the water
- choose to describe the motion as pure rotation, without translation
then A is the center of rotation implied by your choices. But these are choices you make, not something absolute.
You mean roatition is spin around point(cm) inside object ,and translation along circular path is around point outside of object?A.T. said:You are confusing "rotation" with "translation along a circular path".
A boat rotates while driving in a circular path, but in general rotation is not required while tracing/translating a circular path. A space telescope (my example) will move in a circle (orbit) without rotating.John Mcrain said:Dont understand..
What if you're driving the boat?Camera show reference frame of water, so I answer for this frame.
Around what boat rotate?russ_watters said:A boat rotates while driving in a circular path, but in general rotation is not required while tracing/translating a circular path. A space telescope (my example) will move in a circle (orbit) without rotating.
As many others have said, you can choose anything you want. Me personally, since a speedboat's direction of motion isn't well tied to the direction it is pointing, I'd prefer describing the rotation as being about the center of mass (or helm). Especially if I'm the one driving it.John Mcrain said:Around what boat rotate?
It's a still image, so you cannot tell anything about the reference frame of the camera.John Mcrain said:Camera show reference frame of water, so I answer for this frame.
That is one possible way to describe the motion.John Mcrain said:You mean roatition is spin around point(cm) inside object ,and translation along circular path is around point outside of object?
To communicate you need to agree on what words mean. Centripetal force on an object doesn't imply that the object is rotating (changing orientation), just that it's center of mass is translating along a non-linear path, in inertial frames of reference.John Mcrain said:Isnt this game of words?
Yes! That is the issue indeed. You are making a claim that there is some unique point (but you cannot define it). We are telling you that it depends on how you define things.John Mcrain said:Isnt this game of words?
Let´s consider an example where discussing "axis" which does NOT contain the centre of mass is the natural convention...Vanadium 50 said:Bodies do not rotate about a point. They rotate about an axis.
Why does the axis contain the COM? It doesn't have to, but that's usually what we mwan by the word "rotation". The earth rotates about its axis (which contains the COM) but revolves around the sun. It's a convention to aid discussion.
Now one might say "yeah, but this is just terminology" and it is. But when trying to understand something, it's better to keep the potential miscommunications to a minimum.
If ask like this; in what point passes axis(perpendicular to water surface) of circular motion of the boat?Dale said:Yes! That is the issue indeed. You are making a claim that there is some unique point (but you cannot define it). We are telling you that it depends on how you define things.
That is indeed the point of my challenge to define what you mean with full mathematical rigor. If you do so you will find that there is an element of choice in the definition or that it doesn’t produce a unique point.
Who says that it is circular motion? It could be cycloidal or helical as well.John Mcrain said:If ask like this; in what point passes axis(perpendicular to water surface) of circular motion of the boat?
Is now answer only point A?
White path at sea is circular, at the center of that circle passes axis of boat "circular motion"jbriggs444 said:Who says that it is circular motion? It could be cycloidal or helical as well.
But you still have not defined what you mean by a center of rotation.
The trajectory is only circular when projected onto a two dimensional surface in a particular way.John Mcrain said:White path at sea is circular, at the center of that circle passes axis of boat "circular motion"
In my task boat circle motion is known not something that I must find out..jbriggs444 said:The trajectory is only circular when projected onto a two dimensional surface in a particular way.
Now you have to figure out how to nail down the details of that projection.
Nobody but you is discussing the motion. Everyone else is discussing how to describe the motion.John Mcrain said:In my task boat circle motion is known not something that I must find out..
This is a good start to a definition for the center. The velocity defines a unique direction in a given frame. Perpendicular to the velocity defines a plane. How are you planning on picking out a specific point in that plane? We don’t want to use the water since there are many scenarios with rotation but without water.John Mcrain said:If ask like this; in what point passes axis(perpendicular to water surface) of circular motion of the boat?
The point is that we choose the center of rotation (rather arbitrarily) in order to simplify the translation. The center of rotation is not something that is part of the world, it is part of the analysis.John Mcrain said:My answer is I dont know..and dont understand what is the point
But if we relativize center of rotation/circular motion, that mean in real life this point dont exist in space.Dale said:The point is that we choose the center of rotation (rather arbitrarily) in order to simplify the translation. The center of rotation is not something that is part of the world, it is part of the analysis.
Dale said:If they did not then the center of mass would not be traveling in a straight line. This would violate Newton’s first law.
Indeed, you can choose any body-fixed reference point together with any body-fixed (Cartesian) basis to describe its motion. Of course you can choose a very stupid reference point to make simple problems unsolvable (or at least very hard to solve).Dale said:The point is that we choose the center of rotation (rather arbitrarily) in order to simplify the translation. The center of rotation is not something that is part of the world, it is part of the analysis.
These are two different things. You are confusing yourself by lumping them together. Rotation (changing orientation) and motion along a circle (translation) are two independent components of motion. You can have one without the other.John Mcrain said:But if we relativize center of rotation/circular motion,
Yes, A is the static point in the frame of the water that the boat translates around along a circle. But the rotation of the boat (changing orientation) is a separate issue, and the point A is not the only point that can be used as reference for rotation.John Mcrain said:if you swimm at point A you will see that boat moves around you.
Boat moves in circle around point A, but boat do not rotate(change orientation) because allways same side of boat looking toward point A.A.T. said:These are two different things. You are confusing yourself by lumping them together. Rotation (changing orientation) and motion along a circle (translation) are two independent components of motion. You can have one without the other.Yes, A is the static point in the frame of the water that the boat translates around along a circle. But the rotation of the boat (changing orientation) is a separate issue, and the point A is not the only point that can be used as reference for rotation.
Perhaps I shouldn’t have said “violates” Newton’s first law in the first. Something like “complicates” would have been better.John Mcrain said:Isnt this two answers in contradiction?
Well that took a turn I didn't expect! This coordinate isn't a normal rectangular/Cartesian coordinate system centered on point A then, since the boat points up, then left, then down. You're trying to use polar coordinates.John Mcrain said:Boat moves in circle around point A, but boat do not rotate(change orientation) because allways same side of boat looking toward point A.
Boat dont spins around itself.
