Why do small bodies stay in orbit around large bodies?
  • Thread starter Thread starter Jireat
    bodies Orbit
Chaos theory suggests that even small changes in gravitational pull between celestial bodies could affect their orbits. However, the discussion clarifies that orbits are generally stable over long periods, and minor perturbations do not lead to drastic changes in distance. Instead, significant energy dissipation is required to alter orbits enough for bodies to collide or drift apart. The stability of orbits is maintained by conservation of energy and momentum, allowing for minor adjustments without catastrophic outcomes. Overall, celestial mechanics demonstrates that while gravitational interactions are complex, they do not lead to the expected chaotic behavior in stable systems.
Jireat
I know this sounds like an elementary question with an easy answer.
However, I was thinking about chaos theory. Planets and stars are always changing so that their gravitational pulls towards other objects varies. Shouldn't the tiniest change between the pull of a star and a planet, or a planet and its moon (change due to rotation or distance [elliptical paths]) cause smaller objects to either get increasingly close or increasingly far from the large objects, per unit time?
Thank you in advance!
No. Why do you think this would be the case?
The orbits you see today are those which happened to be stable enough to survive millions of years. They might be changing slightly over time, but those changes are constrained by energy and momentum conservation, so a planet cannot just fly off.
Orodruin said:
No.
Wouldn't you say that it's actually a yes, as long as you give n-body interactions enough time?
I would say the OP deals with a two-body system:
First: How "tiny" is "tiniest"? Its pretty tiny: you can Google it for Earth.
Second, a lot of people have a misconception about orbits, that they are very unstable and that the slightest perturbation will cause the objects to spiral apart or together. In reality, they are very stable and even a major perturbation will only reshape them: To make two objects that are in a circular orbit crash into each other requires dissipating almost all of the orbital energy. Much less and you just change the shape into a more elliptical orbit.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
