Mentor
- 37,242
- 16,361
From Nilsson and Riedel "Electric Circuits" 5th ed. section 1.1 p. 5 under the heading "Circuit theory" the assumptions are:vanhees71 said:Well, then tell me which additional assumptions you need for the KVL
"1. Electrical effects happen instantaneously throughout a system...
2. The net charge on every component in the system is always zero. Thus no component can collect a net excess of charge, although some components, as you will learn later, can hold equal but opposite separated charges.
3. There is no magnetic coupling between the components in a system. As we demonstrate later, magnetic coupling can occur within a component."
The same assumptions are worded slightly differently on Wikipedia at https://en.wikipedia.org/wiki/Lumped_element_model#Lumped_matter_discipline and I assume in all other good textbooks on circuit theory. Dr Lewin's example violates assumption 3, an inductor or a transformer does not.
Then why did you make the opposite claim and then falsely attribute such an obviously wrong claim to me when I said no such thing?vanhees71 said:E.g., of course in circuit theory you treat also transformers as "compact element", i.e., a "four pole"
And Maxwell's equations are only a special case of the general QED. And Newtonian gravity is only a special case of the EFE. Shall we claim to be using QED and GR to solve a "push a box up an inclined plane" problem? Shall we say that Newtonian mechanics is "for the birds" because there are some cases where it doesn't work?vanhees71 said:BTW Circuit theory is only a special case of the general "transfer approach" for the full Maxwell equations
