Why does air escape through a pinched ballon?
  • Context: High School
  • Thread starter Thread starter sameeralord
    Air Escape
The discussion clarifies the mechanics of air escaping from a pinched balloon, emphasizing that the internal pressure of the balloon is higher than atmospheric pressure due to the elasticity of the rubber. When the balloon is pinched, the volume decreases, causing the internal pressure to increase, which forces air out. The pressure inside the balloon is influenced by both external atmospheric pressure and the elastic tension of the balloon material. This understanding corrects the misconception that internal and external pressures are equal when the balloon is inflated.
  • Understanding of basic physics principles, particularly pressure and elasticity.
  • Familiarity with the concepts of atmospheric pressure and internal pressure.
  • Knowledge of the behavior of gases under varying conditions.
  • Basic comprehension of balloon materials and their properties.
  • Research the relationship between pressure and volume in gases using Boyle's Law.
  • Explore the concept of surface tension and its effects on balloon dynamics.
  • Study the elasticity of materials, focusing on rubber and its applications.
  • Investigate the effects of altitude on atmospheric pressure and its implications for balloon inflation.
Students of physics, educators explaining gas laws, and anyone interested in the physical properties of materials and their behavior under pressure.
sameeralord
Hello guys,
This is simple question but I have gone completely blank. Ok let's say there was a balloon outside that was inflated. This means that it has expandes so it's pressure is equivalent to atmpospheric pressure right?
So when I pinch it why does air escape, how does balloon suddenly have higher pressure to make air move out? Is pinching the balloon equivalent to making the volume of the balloon smaller. Thanks :smile:
I believe the answer to this question isn't about the atmospheric pressure, but about the force that the elasticity of the rubber of the balloon has on the air. What happens when you stretch the rubber and let it go? It returns back to its original shape right? The same thing in this case. The expansion of the rubber is just stretching it, so when it has the opportunity, the balloon will go back to its original shape and size, thus pushing out the air.
The answer to this question is all about pressure. The pressure inside a balloon is not equal to the atmospheric pressure. In particular,
This is not correct.
I have heard the same thing before (pressure inside a balloon= pressure outside), from a physics teacher or something like this...so I'm not surprised that OP is asking this question. I was wondering the same thing.
I think I resolved it to myself by dismissing what the physics teacher said as BS, though. Sure the balloon expanded, but the expanded balloon is nevertheless pressing on the air inside of it, so surely the pressure must be higher.
Yup .. the internal pressure must be higher to balance both the external pressure + the "surface pressure" from the elastic material of the balloon. This latter term is directly proportional to the surface tension, and inversely proportional to the radius (assuming a spherical shape).
If you took a deflated balloon up into space (assume ambient pressure is zero). Let a small amount of air into the balloon. It will inflate until the pressure balances. It could well burst if you put 'too much' air in but, if it settles down, the pressure inside will be finite and the pressure outside will be zero. The pressure inside is due, entirely, to the forces of tension in the balloon membrane.
  • · Replies 46 ·
  • · Replies 45 ·
  • · Replies 69 ·
16K
  • · Replies 31 ·
