Why does light travel at varying speeds through different materials?
Light travels at varying speeds through different materials due to interactions with atoms, which can slow its effective speed despite it moving at a constant speed in a vacuum. For instance, light moves at only 38 mph through supercooled sodium because of these interactions. The discussion also addresses the paradox of light being massless yet affected by gravity, clarifying that in both Newtonian and General Relativity frameworks, the trajectory of light is influenced by gravitational fields regardless of its mass. The bending of light's path in a gravitational field is consistent with predictions made by Einstein's General Relativity, which was confirmed by observations during a solar eclipse. Understanding these principles helps clarify the complex behavior of light in different contexts.
azzkika
Why does light travel at varying speeds through different materials??
why does light travel at different speeds through different materials??
for example, it travels at 38 mph through super cooled sodium.
also, if light is massless, why is it susceptible to gravity?? i don't know the formulae to examine, but i'd think mass is a factor when calculating gravity, and if so would a zero mass mean gravity has no effect, therefore meaning light does have mass??
Science news on Phys.org
Does light speed vary, or does its path and interactions vary?
good counter-question
It might help you to visualize a ray of light traveling through a mess of atoms. If the light is hitting atoms, won't it take longer for it to get through the material, even if it's traveling at a constant speed while it isn't hitting anything?
informative link, thanks.
i'm still puzzled as to why light is susceptible to gravity, yet defined as massless though.
1)You are making a non-relativistic consideration, that is a Newtonian consideration, while things are more complicated (General Relativity).
2) But even within the simple Newtonian physics, you can take a particle of mass m, look at the trajectory it follows in a grav. field, then reduce its mass to m/2 and look that its trajectory is still bent (if you remember, an object's acceleration in a grav. field does NOT depend on its mass); then make the mass go to zero: nothing changes, so at the limit m = 0, your massless particle still have to follow the grav. field. and so bend its trajectory.
3) The prediction of General Relativity is that the amount of bending of the particle's trajectory, at the limit m --> 0, is double than that calculated in the previous way.
4) The famous experiment of star's light deviated from the sun during an eclipse in the 30', showed that the correct prediction was that of Albert Einstein's General Relativity Theory.
