Why does my netball go the wrong way?
  • Thread starter Thread starter i-like-maths
Kicking a football can create a curl effect based on the ball's spin, which is influenced by the part of the foot that strikes the ball. When a right-footed player kicks a football, it typically spins anticlockwise and curls to the left. However, when the same player kicks a netball, the ball may spin anticlockwise yet curl to the right, which seems counterintuitive. This discrepancy can be attributed to the differences in ball design, particularly the surface texture and joints. These factors create varying air resistance and turbulence, affecting the ball's trajectory. The discussion highlights that the initial conditions of the kick, including the foot's contact point and the ball's surface characteristics, play crucial roles in determining the curl direction. Additionally, the complexities of ball dynamics are illustrated through comparisons with golf balls and American footballs, emphasizing that the physical properties of each ball type significantly influence their behavior in flight.
i-like-maths
You know when you kick a football/soccer ball you can make it curl to the left if you kick with your right foot?
I tried doing that with a netball and much to my surprise, it curled to the right.
Does anyone know what has happened?
I did this in low wind conditions.
ASFAIK it is not a matter of which foot you use, but what rotation the ball gets.
So when my foot hits the side of the football, it starts spinning anticlockwise and curls in the same direction. Yet when I kick the netball, it spins anticlockwise and curls in the opposite direction. Doesn't make sense.
"Kicking the ball" is far from being a safe condition to make an educated guess.
E.g. whether the kicked ball curls to the right or to the left also depends on which part of the foot you kick it with, i.e. the initial rotation. Another example is a golf ball. Players can play hooks to both sides, independent of whether they are right or left handed.
The curl itself depends on the ball's surface, which isn't smooth. Especially the joints play a crucial role, because they cause tiny turbulences which in return cause differences in air resistance on each side of the ball, which at last causes the curl.
So my favorite explanation is: Without additional information on the starting conditions, it's primary the joints and secondary the surface structure, which are typically both different on a football and a netball. Also think about the fact, that American football "balls" have joints along the direction it is thrown. This also explains, why extra points or long distance kicks aren't as easy as one might think.
so does this apply to soccer balls
Yes, especially there - at least as far as I remember a TV documentation on this subject.
Not that this is a trustful source on a scientific level, however, it provides a reasonable imagination.
I've used football = soccer and American football ≠ football.
Similar to the 2024 thread, here I start the 2025 thread. As always it is getting increasingly difficult to predict, so I will make a list based on other article predictions. You can also leave your prediction here. Here are the predictions of 2024 that did not make it: Peter Shor, David Deutsch and all the rest of the quantum computing community (various sources) Pablo Jarrillo Herrero, Allan McDonald and Rafi Bistritzer for magic angle in twisted graphene (various sources) Christoph...
Thread 'My experience as a hostage'
I believe it was the summer of 2001 that I made a trip to Peru for my work. I was a private contractor doing automation engineering and programming for various companies, including Frito Lay. Frito had purchased a snack food plant near Lima, Peru, and sent me down to oversee the upgrades to the systems and the startup. Peru was still suffering the ills of a recent civil war and I knew it was dicey, but the money was too good to pass up. It was a long trip to Lima; about 14 hours of airtime...
