I Why does normal distribution turn into t distribution when variance is unknown?
When the population variance is unknown and the sample size is small, the sample mean no longer follows a normal distribution but instead follows a t distribution. This occurs because the sample variance, which is used in the t-statistic, is itself a random variable that has a chi-squared distribution. The t-statistic is defined as a ratio of a normal random variable (the sample mean) to the square root of a chi-squared random variable (the sample variance), leading to a t distribution. The choice of using the t distribution reflects the uncertainty in estimating the population variance from a small sample. Thus, while the mean retains a normal distribution under certain conditions, the use of the t-statistic is crucial for accurate statistical inference when variance is unknown.
Happiness
Suppose ##X## ~ N(##\mu##,##\sigma^2##). Then ##\bar{X}## ~ N(##\mu##,##\frac{\sigma^2}{n}##), where ##\bar{X}## is the random variable for sample mean for samples of size ##n##.
But when the population variance ##\sigma^2## is unknown and the sample size ##n## is small, ##\bar{X}## no longer follows a normal distribution but instead follows a t distribution, such that ##T=\frac{\bar{X}-\mu}{S/\sqrt{n}}## ~ t##_{n-1}##, where ##s^2=\frac{n}{n-1}\times##sample variance##=##the unbiased estimator of the population variance and ##n-1## is the degree of freedom of the t distribution.
My question is why does the distribution of ##\bar{X}## changes just because we do not know the population variance? Shouldn't the population variance still be some fixed value ##\sigma^2## (it's just that it's unknown to us at the moment), and thus making ##\bar{X}## follow a normal distribution still: ##\bar{X}## ~ N(##\mu##,##\frac{\sigma^2}{n}##)? It seems that objective reality (the specific distribution of ##\bar{X}##) changes according to subjective knowledge (whether we know ##\sigma^2## or not). And this I find puzzling.
We should first observe that you are making some statements that are only true when ##X## has normal distribution.
That is not correct. ##T## and ##\bar{X}## are different random variables. ( A "statistic" is defined as a random variable that is a function of the values in a sample. ##T## and ##\bar{X}## are statistics. )
It isn't the distribution of ##\bar{X}## that changes when the sample size is small. Instead it is the choice of which statistic people prefer to use when doing statistical tests.
When the sample size is large, people approximate ##\sigma^2## (the population variance) by the sample variance of the particular sample they have, in the belief that the sample variance computed from a large sample is probably close to the population variance. They assume ##\bar{X}## has distribution ##N(\mu,s^2/n)##.When sample size is small there is less reason to believe that that the sample variance of a particular sample is close to the population variance. So people use ##T-##tests to make decisions. The distribution of ##T## is not the same as a normal distribution. However, this does not change the fact that ##\bar{X}## still has distribution ##N(\mu,\sigma^2/n)## (provided ##X## has a normal distribution).
Likes StatGuy2000, Happiness and FactChecker
The mean has normal distribution as it was said.
As for the t-statistic T, you first need to see that the sample standard deviation is a random variable (it contains the sum of squares of X, hence it could never be a "fixed value" as you suggested), and that it has a chi-distribution (or equivalently, sample variance has a chi-squared distribution). Check the 2nd post here for a proof: https://stats.stackexchange.com/que...bution-of-variance-a-chi-squared-distribution
Afterward, you can see that the t-statistic T is a ratio of a normal random variable with a chi random variable. You can check why this means that it has a t-student distribution here: https://stats.stackexchange.com/que...sqrt-chi2s-s-gives-you-a-t-distribution-proof, where his W equals your s^2 and his s equals your n.
If the population's variance was known, you would use that instead of S^2, and the only random variable in T would be the mean, with a normal distribution. In that case, T would have normal distribution as well.
The sample variance ##s## is still a random variable, even if the population variance is known. The ##T##-statistic still has a ##T-##distribution instead of a normal distribution even if ##\sigma## is known. If you used a constant in place of ##s## in the formula for ##T##, you wouldn't be computing the ##T##-statistic. So while it is true that replacing ##s## by ##\sigma## in the formula for the ##T##-statistic changes the formula into a formula for a normally distributed random variable, technically that random variable is no longer ##T##.
I'm aware, and T would just be the variable's name and not representative of the t-statistic.
"Afterward, you can see that the t-statistic T is a ratio of a normal random variable with a chi random variable."
An important word is missing: independent. The sample mean and sample standard deviation have to be independent in order for the statistic T to have a t-distribution. Assuming the data come from a normal distribution ensures that independence.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
