Why does taking the logarithm of both sides not work?
  • Thread starter Thread starter Hypercubes
    Logarithm Work
Hypercubes
Differentiate x=e^{-x}
The attempt at a solution
\ln{x}=\ln{e^{-x}}
\ln{x}=-x
\frac{d}{dx}\left(\ln{x}\right)=\frac{d}{dx}\left(-x\right)
\frac{1}{x}=-1
The correct answer is 1+e^{-x}. I know how to solve it that way; however, why is the above method wrong? I know there are usually two variables, but I can't see any mathematical errors in my method.
Thank you.
Hi Hypercubes! :smile:
Obviously a misprint, for "Differentiate x-e^{-x}" :wink:
Well, the exact question was "explain why the equation e^{-x} = x has exactly one solution", and the answer goes on to define f(x) = x-e^{-x} and says "Since f'(x) = 1 + e^{-x}, and 1 + e^{-x} > 0 for all x, the function f is increasing..."
So they set it to 0 to get the derivative. However, why was the method I used not valid?
Your expression, x=e^{-x} is just that -- an expression. You cannot treat it as a function. In particular, you can't differentiate both sides and expect something meaningful to pop out. What you can do is to rewrite it as x-e^{-x} = 0, and now the quantity on the right hand side f(x)=x-e^{-x} can be treated as a function. You aren't differentiating both sides of f(x)=0. Just one.
Ah, I see. Thanks you both!
As a simple example. Take the equation 3x-2=x. This equation has 1 solution x=1. If you differentiate both sides though, you get 3=1 which is obviously not true.
This is because the undifferentiated equation is asking a fundamentally different question than the differentiated equation. The equation 3x-2=x is asking "When is the function f(x)=3x-2 equal to the function g(x)=x?" While the differentiated equation is asking "When is the slope of the function f(x) equal to the slope of the function g(x)?"
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
